1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
Ac and Heating issue.
Old Aug 29, 2007
jroy3221's Avatar
jroy3221 is an unknown quantity at this point
It seems that my ac is going, it will not blow anything on level 1 or 2, but it will blow on 3 and 4. Same with the heat. The air is also not as cold as it use to be. What is going on? I was told i might need a new Blower? If so how much do they cost and are they easily installed?
Old Aug 29, 2007
YSIDRAG's Avatar
YSIDRAG is an unknown quantity at this point
Re: Ac and Heating issue.
it sounds like the lower leavel of the blower motor resister has gone bad. it controls the speed the blower turns. it is a seprate peice and probly alot cheaper then a blower motor. but this would have not a thing to do with how cold the a/c is. hope this helps you some.
JAY
Old Aug 30, 2007
jroy3221's Avatar
Thanks man, you were a big help!!
Old Aug 31, 2007
YSIDRAG's Avatar
no problem. let me know when and if you get it fixed.
jay
Old Feb 17, 2008
dtyler's Avatar
dtyler is an unknown quantity at this point
So what happened? Did you fix it?
I have a Civic LX'99, the air is at full blast whenever I turn on the car, and stay on full blast regardless if I turn off the blower, or set it to level 1 or 2, it stayed at full blast.
Everything else related to it works. A/C works, heater works, or just plain air works also, it just would not SHUT UP! If I can at least switch it ON or OFF, I would be able to put up with it, but no, every time I switch on the ignition, there goes the blower at full blast.
Finally found the "heater motor relay" in the fuse box under the hood, if I remove that relay, the blower would at least stay quiet. Is that part the problem? Is the heater motor relay moderating the speed of the blower? I have one on order (part# 056700-7250), will see tomorrow if that fix it.
Why me? How come nobody has this problem? Didn't find anything on the Internet. Does everybody just take it to the dealership? I would, but the nearest one is 100 miles away, and I hate driving long-distance (even just once a year).
And to boot, this one is less than 40,000 miles, really, even though it is a '99. It is kept in the enclosed garage full-time. It is my #2 car, I bought it used in 2000 when it had less than 20,000, worked perfectly up till now.
Sure appreciate any info, or even just educated guess. I am not a car person...
Old Feb 6, 2015
Flex Wilson's Avatar
Flex Wilson is an unknown quantity at this point
ok so im new to this this site and my blower motor was only working on 3/4 but not 1/2 i knew that was the resistor pack but then just two days ago as i'm coming home from school i start to smell wires burning so i pull over shut my blower off and inspect the blowers wires and everything under the passengers dash nothing was on fire looked at fuses and relays nothing seemed bad so i got back in my car to proceed home start the car up then try to turn the heat back on now none of the speeds work next day go to get new resistor pack replaced it still doesn't work someone please help me it's so fing cold outside and i also don't wanna have my windows fog up on me and get me killed.
thank you it's a 1994 civic EX
h4ldol
Apr 24, 2017 08:16 PM
Munzy
21
Oct 7, 2015 07:48 AM
jeffsasse
Sep 25, 2015 10:08 AM
hondalx2002
18
Sep 15, 2015 10:54 PM
SolidHollow
15
Sep 13, 2015 11:18 AM
