Air Conditioning Post issues with air conditioning here
2003 Civic Si HB - Heater/AC fan not working
Old Mar 5, 2013
surelock22's Avatar
KGZA / Kenny Genius
surelock22 is an unknown quantity at this point
Howdy. My baby blue isn't kicking out any type of air when I turn the ****. I checked the fuses and everything looks fine. I've been told that it's either a loose wire, a bad switch, or a bad fan motor. My car isn't overheating either. I don't feel any air being pushed by a fan, but when it's 20 degrees F outside and you're driving you can feel the heat kinda radiate out of the vents, but that doesn't do me any good when I need defrost. Any help would be appreciated. Thanks!
Old Mar 5, 2013
mikey1's Avatar
Re: 2003 Civic Si HB - Heater/AC fan not working
test for voltage at the fan connector with the fan turned on....
if voltage is present, the fan is shot
Old Mar 5, 2013
CraigW's Avatar
Take the cabin filter out, turn fan switch on and watch the white fan blades when you 1st turn the key to II to see if they spin for a very short time.
usajags84
May 10, 2015 08:11 AM
Ian SFBA
Interior DIY
Apr 25, 2015 02:25 PM
Fastfebur
Apr 22, 2015 01:37 PM
dooner24
Apr 14, 2015 07:51 PM
deus-ex
Apr 13, 2015 12:29 PM
