Engine start problems Post issues with engine start here. Does not start, does not run, etc.
01 Civic EX Cranks But No Start
Old Oct 2, 2022
TinyTiger's Avatar
TinyTiger is an unknown quantity at this point
Car cranks but wont start, fuel is making it to the rail but the injectors will not spray. Previous owner had replaced both the cam and crank sensor with junk Import Direct parts and, after replacing the cam with a Beck Arnley I had lying around, the vehicle started up fine. The only problem was if I let it idle too long it would stall. So I went ahead and replaced the crank aswell, this time with a Denso, and while I was in there also replaced the timing belt and water pump. After that the vehicle ran perfectly - until the check engine light came back on after idling for about half an hour. By this point it was almost 1 in the morning and I honestly couldn't be bothered so I called it a day at that. After returning to the vehicle the following day it's now showing the same symptoms it was before the repairs. Cranks but wont start, injectors will not spray, relays are good, grounds are good, havent checked voltage at all.
Old Oct 3, 2022
Colin42's Avatar
Re: 01 Civic EX Cranks But No Start
Try putting a denso in for the cam as well
Old Oct 3, 2022
TinyTiger's Avatar
Cant seem to find one, I've looked all over.
Old Oct 3, 2022
Colin42's Avatar
Dealer
Old Oct 3, 2022
TinyTiger's Avatar
Dealer
It actually turned out to be the temp sensor. Still ordered an OEM cam sensor anyways.
TonyScott
Dec 14, 2022 01:18 PM
Hillbilly304
Aug 29, 2020 09:37 PM
Ted-04
Feb 5, 2019 01:52 PM
Ken71701
30
Oct 28, 2016 08:20 AM
[H]ashlee[H]
18
May 21, 2010 05:38 PM
