Engine start problems Post issues with engine start here. Does not start, does not run, etc.
01 Civic Ignition and ECU Replacement Troubleshooting
Old Mar 15, 2011
BenJahMin1's Avatar
BenJahMin1 is an unknown quantity at this point
Hello. I have an 01 Civic that I didnt have the key for when I bought it so I bought a new ignition from a local Honda specialty used parts yard. I also realized that the ECU had burned out so I bought a new ECU from the same place. They are pretty knowledgeable so I am confident about the compatibility. There was also an aftermarket alarm installed that I removed and replaced all broken connections. The car will not turn over. The starter will not engage from the key. I jumped the starter and the starter is not bad. I get a clicking sound in the under hood fuse box and its coming from a large silver relay. I decided then that I would attempt to check the OBD for codes or any type of hints but the OBD scanner wont sync. It just turns off. If anybody has any ideas or help they can give me I would appreciate it greatly. Thanks in advance, -Ben
Old Dec 10, 2019
Billardmac's Avatar
Billardmac is an unknown quantity at this point
Re: 01 Civic Ignition and ECU Replacement Troubleshooting
Did you ever figure out the problem? I did the same replacement and it has me stumped
Old Dec 11, 2019
BrotatoChip's Avatar
Super Moderator
This thread is from 2011, you are very unlikely to get a response from OP.
Give us some detail on your issue.
fabled523
Dec 20, 2016 07:57 PM
nasir600
Apr 2, 2013 10:17 AM
CivicMexicano
Engine Swaps
Apr 5, 2009 11:10 AM
carlosp38
Jan 25, 2007 03:33 PM
Jdm01Em2
Jul 29, 2006 02:28 PM
