Auto Transmission failures Post your issues with auto transmission failures here. 01-03 have had a high failure rates
01 civic ex no overdrive
Old Dec 4, 2020
Andybobandy's Avatar
Andybobandy is an unknown quantity at this point
I have an 01 civic with a bmxa trans that’s not going into any sort of overdrive(not sure if it has it really?) and slips between 3rd and 4th. Revs high between gears. With the good ole p0740 code. It stays at about 3000 rpms at 60-65 mph so the tc isn’t locking and there definitely isn’t a 5th shift. I understand these transmissions are pretty crap, and I should just rebuild or replace it witch I will, but what exactly is causing this? Bad tc? Shift solenoid?(testing and checking this again tmro) clutches? Any input is awesome so I can at least make this trans last a wee bit longer and kinda bullet proof the next one I get. Thank you!
Old Dec 5, 2020
Re: 01 civic ex no overdrive
they have only 4 gears
Old Dec 7, 2020
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
IMO the P0740 code for the transmission is the death code and you are on borrowed time until it quits.
The internal ATF filter screen inside the trans is most likely clogged with clutch debris and is restricting the ATF flow. Internal filter, screens on the solenoids and ports and orifices most likely clogged up with debris.
You could do a 3 times drain and fill of Honda DW-1 with driving to operating temps and run through all gears between D&Fs but at this point it may be too late. Common advice is to do a drain and fill every 30K miles (at least) of DW-1 to maintain the quality of the fluid.
Sorry to be the bearer of bad news - I feel for you - I had an Odyssey with a failed trans (code was P0780).
Old Mar 27, 2021
rose62's Avatar
rose62 is an unknown quantity at this point
I don't know if my problem with my '01 is the same: As I'm driving, the trans simply loses od and the engine revs freely with no trans engagement. If I put it in D3 it will go all day. Let it sit over night and the next day it's fine. When this happens it is usually preceded by very hard shifting. The CEL is on, but it's been on forever. I have removed as much trans fluid as I can, 3-4 times and refilled with fresh fluid and a bottle of Lucas.
Is it possible that it's just some sort of solenoid problem?
Old Mar 28, 2021
FRSam's Avatar
Click Here
What’s the code?
Old Mar 31, 2021
rose62's Avatar
I've been job hunting all week, so thanks for the reply.
I've got a buddy at work who has an OBD tester but I haven't yet plugged in (job hunting, not been to work). I'll update asap
It's just weird how it will act normally for a few weeks, then, take suddenly take a crap.
Old Apr 9, 2021
rose62's Avatar
P0730, wrong ratio
Old Apr 9, 2021
FRSam's Avatar
Click Here
Originally Posted by rose62
730, wrong ratio
It could be a bad shift solenoid or vehicle speed sensor. Or, your trans is just toast.
Click me for more information
Old Apr 9, 2021
BrotatoChip's Avatar
Super Moderator
Very likely the transmission needs replaced or rebuilt. Transmission failures in the '01 are very common. Here's another thread with the same code...
https://www.civicforums.com/forums/3...ure-02-ex.html
Old Sep 21, 2021
rose62's Avatar
Update: I recently replaced all the external solenoids. It improved the 1-2 shift noticeably. I'm still losing overdrive but less frequently. However, recently when I pulled away from a traffic signal the trans wouldn't shift out of second. I had previously noticed that occasionally that when the problem would occur, if I drove a while in D3 then parked in a space from which I had to reverse out of, the problem would go away. So when it was stuck in second (and having another 30 miles left in my commute) I pulled into a subdivision, put it in reverse and jabbed the accelerator a couple of times and viola!, drove the remainder of the way home, trouble free. No doubt the trans will fail at some point, probably sooner than later, but I will wring out of it all that I can.
Ndnboy
16
Apr 25, 2017 01:18 PM
cris4444
Feb 22, 2014 09:09 AM
MikeDenny79
Transmission
Mar 1, 2013 08:37 PM
1FASGTO
Jul 14, 2012 06:31 PM
01CivCoupe
Aug 27, 2007 04:47 PM
