01 EX manual shift popping out of fifth gear
Have an 01 EX (Canadian SI) 5 speed manual, has recently started popping out of 5th gear on the highway. I have read that this is a common problem. I was just wondering if there is a better year manual trans that I could put in instead of another 01 to fix the issue. Thanks.
Re: 01 EX manual shift popping out of fifth gear
See if the trans is low on fluid.
How old is the fluid?
I've heard both issues can cause weird problems like that.
Change the fluid and see if that helps anything. If it helps, then that was far cheaper and easier than trying to replace the gearbox.
97-DX-Lover
Jun 14, 2015 06:07 PM
Marcus2thextrem
May 10, 2015 03:08 PM
Russps
Nov 8, 2001 02:00 AM
