Auto Transmission failures Post your issues with auto transmission failures here. 01-03 have had a high failure rates
New tranny P0740?
Old Nov 13, 2021
  #31
IfollowUdie's Avatar
IfollowUdie is an unknown quantity at this point
Re: New tranny P0740?
Originally Posted by honda2003
I have the same exact scenario, bought a JDM 2003 Japanese tranny for my US made civic. Tranny looked new 16,000 miles on it. No torque lock up, shifts great. Did you ever find the solution to the lock up problem? ( cleaned and tested all old solenoids and sensors, wiring looks good) No D2 also.
it has nothing to do with the tyranny being bad, solenoids, wiring, sensors or literally anything bad. It's because the JDM autos have 2 more teeth than the US counterparts, doesn't seem like it makes a big difference but it is enough for the ECU to pick it up.
Old Oct 3, 2022
  #32
gothicsunrader's Avatar
gothicsunrader is an unknown quantity at this point
Originally Posted by Jhoff
Ok, I read a lot of info on this and it veries quite a bit depending on where you read. I have read that I am to rest the pressure coming out of the tranny lines and see if they are in spec. If they are then it says to replace the tcc selenoid. I am also considering a tranny flush. I am reluctant to pull the tranny and send it back because it would be 300 dollars to ship it plus the ATF fluid to do it all over again. So here is what I will do for everyone on the web searching this issue. I will flush the tranny, get new selenoids and just drive it with the code on and see what happens. If it fails....it fails. I see a lot of people who just go drop 2500 at a dealership with this cel. I will have the tranny rebuilt if it fails.
So what happened here. I have the same code on a 2002 Honda Civic EX. Tranny has 80,000 miles on it. Only comes on at 60 mph after 5 minutes on open road. I’m thinking of ignoring as there are no other symptoms I can detect. I changed the fluid 3 times and no burnt smell. My Civic was made in Canada. Not sure about the tranny, I didńt do it but it came with a receipt, but doesn’t say much. I’m super interested in knowing what you did in the end. Thx
velozp
Dec 13, 2015 11:28 AM
mistahlorax13
21
Nov 18, 2015 12:47 PM
speedlever
Sep 24, 2015 07:18 PM
FistRock
Sep 4, 2015 08:00 PM
dantheman42
Sep 4, 2015 01:10 PM
