Auto Transmission failures Post your issues with auto transmission failures here. 01-03 have had a high failure rates
Please Help! P1773 02 Honda Civic LX 1.7 auto
Old Sep 14, 2022
jeremy92honda's Avatar
AerialFX
jeremy92honda is an unknown quantity at this point
P1773 02' Honda Civic LX 1.7 auto. Keep getting the same code p1773 after every half hour of driving the CEL comes on a D light flashes. Won't shift gears, very dangerous! Please help me! I Changed CPC solenoid twice, (6 Continuity), alternator, belts, alternator includes Voltage reg., ELD, battery tests fine, and checked all wiring. ECU??
Old Sep 14, 2022
Colin42's Avatar
Re: Please Help! P1773 02 Honda Civic LX 1.7 auto
Trans is probably dead
Old Sep 15, 2022
AerialFX
That was my original thought, but it seems to shift fine. The battery light also has an occasional Flicker and when I seen it flicker I knew the car would mess up. I turned the idle up by unplugging a sensor, it fixed the battery light but the Transmission still throws a code after about 30 minutes of driving... Also, I read p1773 has to be electrical and can't be mechanical. When I put the aftermarket solenoids in, it did rev up before shifting. Other than that, it seems to shift fine? Thanks, Jeremy
Old Sep 15, 2022
https://www.civicforums.com/forums/3...em-solved.html
also, one known issue that fries ECU's is loose alternator bolts - check them
Old Oct 7, 2022
AerialFX
Solved!!!
wasn't the ECU or transmission. Turns out my problem was due to buying an aftermarket AC clutch compressor. Problem has a disappeared ever since I disconnected the relay.
in addition to having problems with shifting it was also pushing radiator fluid out of the overflow tank. That has stopped as well.
Old Oct 7, 2022
BrotatoChip's Avatar
Super Moderator
Keep a close eye on that. Common sign of head gasket failure.
Old Oct 7, 2022
AerialFX
yes, I read that and I will. I was about to buy one and replace it. 145 PSI all four cylinders water pump is running and passed the carbon dioxide test as well.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
j00fek
Jul 19, 2011 10:06 AM
monkeyness
South Cali
Apr 25, 2005 02:44 PM
JoeyOKC
Dec 2, 2004 08:22 PM
Deviouz480EX
Arizona
Dec 6, 2003 12:52 AM
