Transmission compatibility/clutch kit
Old Jun 21, 2022
pimpedoutpepto's Avatar
pimpedoutpepto is an unknown quantity at this point
Exclamation Transmission compatibility/clutch kit
Hello! I am very new to the mechanical side of cars. I’m usually more into body mods, so please keep that in mind that it’s not always easy for me to understand !(: I have 1996 Honda Civic EX. It’s D15B V-Tec. I spoke to my friend and he recommended a 1992-2000 Honda Civic Ex D16y8 Rebuild Transmission S40 B000. Is that a good transmission to go with? If you have any opinions please include a clutch kit and flywheel I should use with the transmission. I’m not being cheap with it, but I’d like it to be somewhat affordable. I prefer a stage 2 clutch. . Also, if you recommend any specific master cylinders. Thank you!!
Old Jun 21, 2022
Re: Transmission compatibility/clutch kit
stock engine does not need any stages. Stock clutch more than enough
Old Jun 21, 2022
Thank you!
Old Jun 21, 2022
no clue about trans, though
Old Jun 21, 2022
Colin42's Avatar
Should be a little barcode/sequence of letters and numbers on your trans. If it starts with s40 then the kit will work.
look for something like this
scotttie17543
Feb 28, 2014 02:55 PM
Desert-Fox82
Oct 18, 2012 10:20 AM
00celicagts6spd
Oct 29, 2003 03:28 PM
hothondacivic02
Bolt-on Engine Performance
Sep 12, 2003 07:06 PM
Silver2k1Dood
Jul 9, 2002 06:16 PM
