98 Civic EX Coupe- 5 Speed Issue
Old Jun 17, 2011
bjackman63's Avatar
bjackman63 is an unknown quantity at this point
I am trying to figure out what went wrong with my civic. While driving the engine disengaged from the clutch and although it starts fine, idles fine, I have good pressure to the clutch can shift through the gear box when I let the clutch out there is no movement. If I step on the gas the engine revs while in gear but does not move. The clutch was replaced 30K miles ago and do not think that is the problem, I think it is below that but have no idea, if you have any thoughts or ideas that could help me figure out what is wrong it would be greatly appreciated.
Thanks,
Brian
Old Jun 18, 2011
dariusld's Avatar
dariusld is an unknown quantity at this point
Re: 98 Civic EX Coupe- 5 Speed Issue
Right before this happened, it was running normal?
Old Jun 18, 2011
02civicsi02's Avatar
Low and slow!
Can you hear the clutch engage and disengage. Reason I'm asking is the slavecylinder could be getting stuck allowing the throwout bearing to still keep it engaged which will be like holdin in the clutch, or maybe the clutch is getting stuck because it maybe not aligned in there right.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
ghondavic
Transmission
Apr 12, 2017 09:37 PM
dragonsblood
Apr 27, 2015 12:28 PM
GH04si
Apr 15, 2015 08:13 PM
skywalker
Nov 8, 2001 05:04 PM
