Looking For Bolts [solved]
Old Aug 6, 2022
LilHonda's Avatar
LilHonda is an unknown quantity at this point
I was doing an alternator swap on my Honda Civic 1999 EX and got stuck halfway through when I realized that I snapped the bolts that connected the outlet line to the power steering pump. I've been searching everywhere for replacement bolts.
The way I see it, I have 2 options:
1. Buy a new power steering pump.
2. Drill the other half of the bolts out.
Either way, I will need new bolts.
None of the Honda OEM parts sites seem to even acknowledge these bolts, and if they do - it's not obvious to me. The official manual for my car (page 228) shows the two bolts in question (vertical). Side note, the manual does not identify the mm size, only the Nm value.
Which approach should I take, and what's the parts number for these outlet line bolts? I guess it's impossible to optimize for both cost and time/effort here.
Thanks in advance.
Old Aug 6, 2022
Colin42's Avatar
re: Looking For Bolts [solved]
Get bolts from the junkyard
Old Aug 8, 2022
BrotatoChip's Avatar
Super Moderator
These bolts? Part number 95801-06030-08. It's an M6 bolt, 30 mm long. Unsure on thread pitch, maybe 0.75.
Old Aug 9, 2022
LilHonda's Avatar
Yea that's definitely the bolts I'm looking for. Thanks for the part number, I was able to find them on HPN and get em. Also where did you get that diagram from?
Old Aug 9, 2022
Re: Looking For Bolts
online honda parts dealers have diagrams.
https://www.civicforums.com/forums/2...retailers.html
Old Aug 10, 2022
Super Moderator
Re: Looking For Bolts [solved]
Found it on HPN under Chassis, P.S. Pipe.
erndog
Dec 30, 2024 09:35 AM
Virtaullyinsane
Mar 31, 2018 06:54 PM
BootyDo
Aug 21, 2016 09:25 AM
Rollin0n18s
May 19, 2002 02:40 PM
crayzhomp
Apr 2, 2002 10:25 PM
