Interior Post your questions about interior parts here! Seats, consoles, etc
Problem with screws in shift knob!
Old Jul 11, 2019
ksplitt99's Avatar
ksplitt99 is an unknown quantity at this point
Problem with screws in shift ****!
1999 CIVIC...the 2 screws were missing from shift ****, so I bought them from Honda. Saw video on YouTube on how to fix. The button, spring, and white nylon bushing over the angled metal rod seem fine, nothing in there is broken. When I put them in, either in Park or all the way back down into position 2, I have to push a tiny bit down on the shift to make screws align with holes, then it shifts fine back into Park, BUT then LOCKS and button won't release and allow me to pull out ignition key. The only way it works is the way it was...with the locking screws out.
What is the problem? Could the spring have lost tension and need new one? Appreciate your expert help, thanks!
Old Jul 13, 2019
mac25's Avatar
Dr Krieger of Modification
Re: Problem with screws in shift ****!
We're talking about an automatic shifter right?
I'm not sure if/where there is a shift lock overide button on the 1999, but there is one on the 2001-05.
It's a small 1/2" x1/4" rectangular plug located on the base of the shifter assembly. You remove the cover and use a small tool like your car keys or screw driver to push it down.
Old Jul 19, 2019
ksplitt99's Avatar
thanks!
Old Jul 19, 2019
mac25's Avatar
Your welcome 😁, glad it worked.
Old Sep 29, 2024
man630's Avatar
man630 is an unknown quantity at this point
I’m having the same problem. Shifter **** screws came out and won’t line up to shaft. I tried pushing down the interlock switch. It does let the shaft go further down . But it won’t stay down. I tried holding the switch down while installing the mounting screws but I still but I still can’t get the key out. No shifting issues before the ****/ handle flew off one day . 1st photo how the shaft looked after the **** came off, 2nd photo travel of shaft with the switch deppressed.
Old Sep 29, 2024
man630's Avatar
Car is a 99 Civic EX
gothman667
Mar 10, 2013 02:14 PM
dimachurin
Dec 11, 2011 08:27 PM
genx_7
Jun 22, 2004 02:49 PM
StealthCivic
Jul 3, 2002 09:15 AM
