Windows not rolling down
I bought my 96 Civic used and the driver rear window never worked. I never looked into it. A couple years pass and the back passenger window stopped working. A couple more years pass and the front passenger window stops rolling down. The driver side still works and has had no issues.
I decided to replace the driver window control module and that made no difference. I replaced all 4 fuses for each window and it had no affect.
It seems the issue cascaded through the windows. What would cause that? What should I look at?
Thanks in advance.
Thanks in advance.
Re: Windows not rolling down
Check for broken wires in the door harness, they usually break near the hinges because the harness flexes everytime the door is opened and closed
Or are you saying check each door's wire at the Jam?
Will the driver door fall victim to the same issue?
Thanks!
There's a bunch of wires wrapped in wiring loom. That makes a harness.
Driver's door gets the most use so that is most likely where the damage is. Check the other doors after that.
Any good manual wiring diagrams online that you know of?
There's literally one on this site available for free. Quick search would have found it.
https://www.civicforums.com/forums/1...nual-free.html
R7derek
Jan 25, 2013 06:51 PM
jwai
Aug 10, 2009 03:58 AM
