Help to identify 3 sensor
Old Apr 25, 2023
Maqcro's Avatar
Maqcro is an unknown quantity at this point
See pictures. I think I broke two of sensors taking off the connector. Looking to get the name of the two sensors on the side under the distributor and one on the back above the oil filter.
thank you.
Old Apr 25, 2023
Colin42's Avatar
Re: Help to identify 3 sensor
Knock
temp sensor or fan switch, can't remember which is which.
Old Apr 25, 2023
Maqcro's Avatar
Originally Posted by Colin42
Knock
thank you that helped A lot to identify the parts online. Looks like the back one is oil pressure, and the two on the side are as you say, coolant and fan sensors.
Old Apr 25, 2023
BrotatoChip's Avatar
Super Moderator
As discussed in your other thread, first sensor is the low oil pressure switch. Knock sensor I believe is to the right in that picture.
Waleed Akbar
Electronics
Jan 15, 2020 09:01 AM
emich
Feb 1, 2019 03:53 PM
Roadkingbob
Exterior
Oct 18, 2017 11:59 AM
cbjfan2009
Mar 10, 2015 05:38 AM
brettf
Oct 1, 2008 12:21 AM
