Guzzling Too Much Fuel
I've a 97 Civic. Replaced many things and can't seem to up my mileage. I use the freeway to get to and from work. I imagine the mileage would increase rather than in stop and go traffic.
Injectors, TP, O2's, Filter were all recently replaced.
Re: Guzzling Too Much Fuel
You definitely should though. If the engine thinks it is running cold, it adds more fuel to compensate.
There are a number of reasons the fuel economy could be low. Anything from failing sensors, sticking brakes, bad tires, bad gas. The list goes on.
So, now the question is if the ECT Sensor is reporting normal operating temps is it also telling the ECM that it is at operating temp and it no longer needs to dump more fuel?
"So, now the question is if the ECT Sensor is reporting normal operating temps is it also telling the ECM that it is at operating temp and it no longer needs to dump more fuel?"
Does anyone have an answer for the quoted question?
That's the mechanic's job, they have the fancy scan tools to determine that
Dticalman01
Jan 30, 2004 01:09 AM
