Losing coolant [solved - HG]
Old Nov 23, 2021
Colin42's Avatar
2000 SI (US EX) D16Y8 auto, 227xxx kms
Noticed the temp gauge at 2/3 2 weeks ago.
Popped the rad cap, it was low and the bottle was empty.
Filled with coolant.
Today I hopped in after the fiance got home and it was at 7/8(!) fiance says she never noticed it was high thankfully the warning light wasn't on
Rad low and bottle empty again, refilled with coolant.
I don't see any obvious leaks in the engine bay, but it was already dark out.
Tested the fan with a power probe and it spins.
Doesn't spin with the AC on but I can't remember if the 6th gens do that or not.
I don't think it's the head gasket, hoping it's just a leak I haven't been able to find.
Any suggestions/advice is greatly appreciated
Old Nov 23, 2021
re: Losing coolant [solved - HG]
coming out of exhaust?
Old Nov 23, 2021
Colin42's Avatar
Not that I noticed, I'll check more closely tomorrow
Old Nov 24, 2021
BrotatoChip's Avatar
Super Moderator
She didn't notice the heat stop working??
Old Nov 24, 2021
Colin42's Avatar
Heat was working when I got in, as soon as I noticed the gauge I cranked it to max and turned back home (2 min drive)
Old Dec 10, 2021
Super Moderator
Ever figure this out?
Old Dec 10, 2021
Colin42's Avatar
Nothing yet, been busy with work. Need to check the level again. Haven't heard about the gauge being high again
Old Mar 11, 2022
Colin42's Avatar
So little update, replaced all the coolant hoses, the rad, and the o-rings on the water pipe on the back of the engine. Leak seems to have stopped. Probably going to do the timing belt and water pump in the summer
Old Mar 11, 2022
Super Moderator
Luckily no bad headgasket.
Old Mar 11, 2022
Colin42's Avatar
Yep, got very lucky
Old Jun 28, 2022
Colin42's Avatar
So it was the headgasket, wasn't really noticeable if the car was driven in town. Driving the car on the highway would make it worse. Driving home last night from the airport I stupidly forgot to check the level before we left. I hurt it bad. Going to see if i can limp it to where my tools are. Ordered the parts last night. Called the machine shop and they quoted me $160 to do the head.
Old Jun 28, 2022
ouch, g'luck...
Old Jul 13, 2022
Colin42's Avatar
Re: Losing coolant [solved - HG]
Ripped the car apart yesterday, head is at the machine shop now.
Old Jul 17, 2022
crajnai's Avatar
7th Gen Victim
crajnai has a spectacular aura aboutcrajnai has a spectacular aura about
I’m right behind you. Trying to decide how much I ‘need’ to disconnect vs ‘have’ to. I couldn’t get the dang engine block drain plug to budge so I’ll be using the shop vac. I discovered my water pipe has both bolts missing too. Oy!
Dice_of_Mars
Jun 15, 2022 11:45 AM
Andym
18
Aug 25, 2021 06:15 AM
WaryDriver
Dec 20, 2016 12:42 PM
AylmerQc
Jun 23, 2013 07:19 PM
Jamiemadroxxx
Feb 23, 2012 05:24 PM
