B18b Swap idle surging and shuts off when in gear
Old Nov 8, 2020
Julian12's Avatar
Julian12 is an unknown quantity at this point
I just did my first swap putting in a b18b into a ek hatch. I am using the p75 ecu and just wired up the things I needed in the original harness. I just did the timing belt, spark plugs and wires and the distributor rotor and cap. I am having surging idle and I can’t seem to find what it is, i start the car and it goes from 1000 rpm to 1600 and keeps going until it’s warm and goes down to 800 to 1000 and when ever I am in gear and try moving the car will stall. I have bleed the coolant mutile times now, cleaned the IACV and adjusted the fast idle valve. There is no vacuum leaks, I’ve tired adjusting the idle screw and won’t change, changed the map sensor and nothing.
what would be the next steps to look into? Change the iacv?
KiwiCivicDriver
Idle Issues
Oct 20, 2019 09:41 PM
CNTLOSE
16
Nov 14, 2014 07:23 AM
jobu123
Jun 20, 2013 08:51 PM
yllager2013
Apr 17, 2013 12:41 PM
95EX
Apr 22, 2010 06:44 AM
