99 Civic EX LS swap won't start
Old Apr 1, 2020
99exls's Avatar
99exls is an unknown quantity at this point
hello ALL
I'm Brandon I NEED HELP PLZ
When I got the car it was running and started up just fine and then one day it just stopped and I've been having to push it off to get it going every day every time I get in it I replace the starter and I replace the clutch switch still nothing can anybody help me with this and tell me how I can narrow it down I find my problem I have all lights on dash and fuel pump cuts on but it will not even turn over battery is good
Old Apr 1, 2020
Colin42's Avatar
Re: 99 Civic EX LS swap won't start
Did you try testing the starter?
Old Apr 1, 2020
Wankenstein's Avatar
This may help: https://www.hondacivicforum.com/foru...uestion-80082/ and this https://honda-tech.com/how-tos/a/hon...-module-374873
I attached the images ICM (ignition control module a.k.a igniter) and Coil from the first link. Also, the best test for the coil is shown in the video below. You can use a long screwdriver to ground in place of the test tool ETCG is using in the video. I use one side of battery jumper cable to attach one clamp to long screwdriver and the other clamp to ground (strut tower's strut nut).
quicksilver53
Nov 12, 2016 02:40 PM
ScottyA
Sep 16, 2014 10:35 AM
ssshassan
Dec 24, 2011 06:50 PM
thatboi901
Jun 15, 2011 10:48 AM
captjohn
Dec 23, 2010 10:19 PM
