NEED HELP Distributor to Coilpack Conversion on a D14 engine
Old Mar 16, 2020
jeremyps's Avatar
jeremyps is an unknown quantity at this point
Hello,
So I wanted to make the change from distributor to coilpacks for better performance and more reliability.I have already done some research but dont deally know what I need. If someone maybe has some time to tell me what would be needed for this conversion, that would be great
The car is a Honda Civic Hatchback Year 2000 with a D14 Non VTec.
Would appreciate the help
Old Mar 17, 2020
mac25's Avatar
Dr Krieger of Modification
Re: NEED HELP Distributor to Coilpack Conversion on a D14 engine
Not worth the time and money. Imo.
Needed
-coil packs
-ecu to drive packs
-compatible wiring harness
-compatible timing sensors (map, tdc,crank)
-probably other stuff.
MCM has an episode on youtube where they converted a car, maybe check that out.
Old Mar 18, 2020
jeremyps's Avatar
Needed
-coil packs
-ecu to drive packs
I want to do it for the reliabilty factor and honestly ive never had a car with a distributor as the ignition system till this this day. Apparantly these distributors struggle at a higher rpm since the spark sometimes is blown out and wanted to switch to a more reliable setup.
But thanks , will definitely watch that MCM for some more understanding
Old Mar 18, 2020
Colin42's Avatar
You're going to spend like $3k + on a car that's worth $1k
marcoberto
General 6th Gen
Apr 27, 2018 01:01 PM
BigBelly1
Dec 15, 2012 03:25 PM
94hondaman94
Mar 1, 2012 06:35 PM
one more
Mar 23, 2011 07:54 PM
Tazim
Aug 26, 2009 10:57 AM
