P0325 knock sensor issues
Old Sep 20, 2019
Djmixmode's Avatar
Djmixmode is an unknown quantity at this point
Hey Everyone. Have a couple of questions here. Some background first - I had to replace my knock sensor because the sensor connector broke off the sensor itself during an upper intake gasket replacement. Obviously it set a hard p0325 check engine light. Once I replaced it, I now get an intermittent p0325 code. Intermittent as in I can drive it around for days before it sets the code and once I reset it, I have a few more days before it turns on again. My first question is, is the p0325 code JUST for if the sensor itself is bad (or the wiring/connector)? Or can it also be for if the sensor actually detects a knock in the engine? Lastly, what other causes of p0325 could there be besides the sensor and related wires/connector? FWIW - I have no drivability issues. No hard starts, rough idles, or surging. Before the sensor replacement (while it was broken) I had horrible gas mileage, I was getting about 25 mpg but after the replacement even with the code being intermittent I'm back up to 35 mpg where I was before the sensor broke. Engine is a D16Y8 for you mobile users lol.
Old Sep 20, 2019
Colin42's Avatar
Re: P0325 knock sensor issues
Did you use an OEM sensor? Honda's don't tend to like aftermarket electronics
Old Sep 20, 2019
Djmixmode's Avatar
No, I wanted to eliminate the stuff in my OP first before I have to pony up the ~$200 for an actual Honda sensor. It wasn't the cheapest knock-off I could find but it wasn't an OEM Honda one either. And I totally get that Honda doesn't tend to like non Honda branded stuff.
Old Sep 21, 2019
Colin42's Avatar
Grab one from a junkyard? It will be dirt cheap and they don't tend to go bad
contevo
May 8, 2015 03:49 PM
smmack15
Bolt-on Engine Performance
Jun 18, 2014 11:59 AM
tide55
Dec 19, 2013 11:37 PM
threeoten
Nov 4, 2012 01:56 AM
keithriej
Sep 8, 2012 12:00 AM
