Rear main seal oil leak
Old Sep 6, 2019
assyria24's Avatar
assyria24 is an unknown quantity at this point
Hello members!
My mechanic said I have a rear main seal oil
leak with an estimate for $700-800 repair. He said it’s best to wait until I need to replace the clutch so he can do it all at once. My questions... is it safe to drive with this issue? Can it start an engine fire or will it damage my engine more? I check the oil level every two weeks and I need to add a quart of oil about every 3-4 weeks. I don’t do freeway driving on my car just around town. I have a 2000 Honda Civic with 271k miles. Thanks for your help!
Old Sep 6, 2019
Colin42's Avatar
Re: Rear main seal oil leak
Doubt it would start a fire you should be fine to drive.
Post up some pictures. Most of that oil is probably going out the exhaust
Old Sep 7, 2019
mac25's Avatar
Dr Krieger of Modification
You're fine, I see 2 to 4 rearmain leaks a month. (Oil shop)
Next time it goes low is Lucas stop leak, 1 full bottle. After that top up with whatever oil you're using.
Next oil change run a high mileage oil and Lucas stop leak.
Or basic oil if you want something cheaper, just dont use synthetic (which is the best lubricant, but also slips through leaks more).
Jan 27, 2016 10:20 PM
Steevo
Oct 28, 2011 09:38 AM
Polski Dan
Nov 19, 2010 10:16 AM
Muirsy
Oct 29, 2009 05:09 PM
SODJAZERO
May 16, 2005 07:51 PM
