Won't start when and after it rains
Old Feb 18, 2019
CliffDog2004's Avatar
CliffDog2004 is an unknown quantity at this point
Hello all,
My 95 Civic has an issue with water and/or moisture.
Like the title says, it won't start when and after it rains.
Funny thing is the hood is closed and the stuff under it appears dry.
If I wait a few minutes, the engine light will finally go off (with a little mechanical sound and click like the fuel pump priming), and only then I can start it.
If it doesn't rain and the light is on, it starts right away.
I've recently changed the dist.cap, rotor, coil, wires and plugs for a tune up. Same problem persists.
When it rains, I need to leave plenty of time to allow the wait needed to start.
It's a real nuisance when I'm in a hurry to get to work because it sometimes takes up to 10 minutes with the ignition ON until I hear the sounds and the light go off.
Any suggestions would be appreciated.
Thanx in Advance!
Old Feb 18, 2019
Colin42's Avatar
Re: Won't start when and after it rains
Something under the dash is maybe getting wet?
Old Feb 27, 2019
No. Nothing inside is wet.
Old Feb 27, 2019
I'll guess it needs an ECM
Sethster99
Apr 6, 2013 12:51 PM
ebanuelos
Dec 26, 2011 07:45 AM
Croxton
Dec 20, 2010 08:46 PM
turboslug
Jul 1, 2004 08:10 PM
IronFist
May 11, 2004 11:25 PM
