Strange power window behaviour
Hello. Ill cut straight to the problem.
my power windows work flawless, except for one thing. If i try to pull up passengers window, from drivers side (main controller) either fuse blows up, all wires start to overheat to a melting point if kept long enough, or melts a fuse, sometimes it works fine and pulls the window up. The down position works perfectly. Passenger side panel works perfectly. Everything works good except this one combination.
Any ideas? Was checking harness, looks fine. I dont know where to start looking, can it be a faulty switch? But no smell of burnt anything there.
Re: Strange power window behaviour
start from the wires at the door hinge. The most common issue, since you need to open/close the door to get into the car and the wires are there
tester
Electrical
Aug 30, 2019 09:59 AM
tester
Jul 10, 2017 08:10 PM
craddmd
Aug 12, 2011 11:37 PM
