Electrical Post your Electrical issues here!
Speedometer needle not calibrated to zero
Old Sep 18, 2020
boc4ever's Avatar
boc4ever is an unknown quantity at this point
For about a year my speedometer needle is on the fritz. If I pull the battery wire it resets to zero. Then after a few days, it starts to believe that various speeds are the zero starting point. Sometimes it starts at 30, 80, 100 or it is all the way at the max. It moves correctly to acceleration and deceleration but it won't recalibrate to zero without disconnecting the battery wire. I even found a video where you perform a series of turns on the key, light switch and the odometer reset button. This will move the needle back to 30 but only for a short period of time. Is this a short in the wiring, computer issue, fuse or do I need to call an exorcist?
Old Sep 18, 2020
mac25's Avatar
Dr Krieger of Modification
Re: Speedometer needle not calibrated to zero
If you did the gauge cluster reset (2001+) then I'd guess, speed sensor is going.
Old Sep 18, 2020
Yeah, if it's a 6th gen, I'd venture a guess on the VSS, too. I'm sure someone will be able to advise how to test if those things are bad.
Also, I almost lost it at the exorcist part.
Old Sep 20, 2020
boc4ever's Avatar
Is speed sensor an easy DIY fix?
Old Sep 20, 2020
Colin42's Avatar
Held in by one bolt on top near the back of the trans. Probably have to get the intake tube out of the way. I would get one from the junkyard before buying an aftermarket one
Old Sep 20, 2020
boc4ever's Avatar
Thanks! I will give it a shot.
Shanvhere
Electronics
Oct 17, 2019 10:38 AM
ProStreetDriver
Oct 16, 2017 01:18 PM
316
28
Jan 15, 2009 02:22 AM
popee
21
Jul 15, 2008 10:40 PM
skarteez
16
Sep 21, 2004 09:36 AM
