HELP! MY battery lights keeps flickering!!!
Old Jul 11, 2008
popee's Avatar
popee will become famous soon enough
so, i noticed about 2 weeks ago my battery light flickering on and off, but it would go away. Now, the battery light continues to flicker on and off and will not stop. i already replaced my alternator and battery. i got it checked out, but they could not figure out why, they tested the new battery and alternater and that was not the problem.
Can anyone think of a possible reason or solution?
Thanks
Old Jul 11, 2008
Tragedy's Avatar
skate or die
Re: HELP! MY battery lights keeps flickering!!!
defective guage cluster?
Old Jul 11, 2008
emjay's Avatar
emjay is a jewel in the roughemjay is a jewel in the roughemjay is a jewel in the roughemjay is a jewel in the rough
its that short wire that runs from ur fuse or sumthing ... u know that short one that can get cut sometimes? someone should know exactly what im talking about
Old Jul 11, 2008
popee's Avatar
what fuse are you talkin about ??
Old Jul 11, 2008
should not flicker, it either comes on ir it doesnt. wire is loose. if alt and batt come up good (make sure the tester knows how to do it), then its a cluster light problem.
Old Jul 11, 2008
popee's Avatar
wouldnt my whole cluster flicker ?? and it only happen when i am driving the battery light flickers,, than i put it in netrual the light doesnt come on i just tryed it on the way to work ,
Old Jul 11, 2008
greeen01civic4d's Avatar
yea, im going with loose wire now, check wires and stuff surrounding the alternator, battery, and all grounds
Old Jul 11, 2008
popee's Avatar
THanks for the help man !!!
Old Jul 12, 2008
CraigW's Avatar
When the charging light flickers, do the headlamps dim or change in any way ??
Is it only happening while the car is moving ??
Old Jul 12, 2008
02whiteem2's Avatar
02whiteem2 is an unknown quantity at this point
Im having the exact same problem. it just randomly flickers quickly when my rpms drop around 2.5k. anyone got a fix for this yet??
Old Jul 12, 2008
try tightening ur alternator belt first. does it squeal when wet? is it dryrotted and cracked?
Old Jul 12, 2008
i had that problem, belt would squeak at first in rain then all the time. turned out the alternator bolt was about to fall out.
Old Jul 12, 2008
popee's Avatar
i going to replace the alternator on tuesday maybe ,, but my belt doesnt squeal,, going to check for cracks
Old Jul 13, 2008
popee's Avatar
nothing dims,,, i even try putting even thing on to see if it dim but nothing,, the battery light jus flickers when i drive!! its stupid! the car idles fine,,,
Old Jul 13, 2008
get ur codes pulled from like autozone, or what ever u have up there in canadia... see if u get any codes, even if ur light isnt on
Old Jul 13, 2008
popee's Avatar
going to get it check out on tuesday,, i am goin got take out my deck to see if it might of cuase the problem..
Old Jul 13, 2008
might be stupid but are the battery clamps tight?
Old Jul 13, 2008
popee's Avatar
thats what i thought was well,, i unhook it and retighten it ,, still nothing ,, this is jus pissing me off
Old Jul 14, 2008
popee's Avatar
soo i got my deck rewire,, thinging it would of solve the problem,, it stop the flickering !!! yea!! but now if i push my car up to 3000RPM,, the battery lights stays on until i shift than rev back up to 3000 it goes back on,, soo iam thinking its my altentor?? correct me if i am wrong,,
Old Jul 15, 2008
popee's Avatar
Update: soo i got the alternator / my belts change.... the battery didnt come,, hopefully this solve my problem... thanks for the people who help'd out
Old Jul 15, 2008
yup def was the alternator. should be fine now
Old Jul 15, 2008
popee's Avatar
HOpe so !!!! was a dumb week,, trying to figured it out..
Burnout
Jul 15, 2022 10:24 PM
HiImBrandon
Jun 1, 2015 07:34 AM
MiniMi
May 27, 2015 01:57 PM
trellex
May 24, 2015 04:39 PM
WLakers
May 4, 2015 06:23 PM
