Electrical Post your Electrical issues here!
96 Civic Temperature Gauge Problem
Old May 15, 2016
vichonda's Avatar
vichonda is an unknown quantity at this point
Unhappy 96 Civic Temperature Gauge Problem
Have civic cx 96 with temperature problem. marks high temp sometimes but at motor temp is ok, fan comes on and off everything normal. checked and replaced temp sending sensor, replaced temp gauge even threw an extra wire from sensor to gauge. car runs ok with temp normal only sometimes it goes up more than half when still. the problem is only when car is still and idle. do to when the problem occurs, replaced radiator after replacing thermostat and even ran it without it and still temp varies. the only thing left is to change the whole dash cluster. thinking to buy a temp gauge and connect the circuit apart from the dash cluster gauge. Any ideas or past experience to this problem?
Old May 16, 2016
Re: 96 Civic Temperature Gauge Problem
Which coolant temp sensor did you replace?
Aftermarket sensor?
Plug in a scantool, read (data list) what the computer is seeing from its temp sensor.
Normal operating temp and most thermostats might open around 180, but the fan doesn't kick on until around 203*F. That extra 20 degrees might be what you see?
Old May 16, 2016
vichonda's Avatar
[QUOTE=ezone;4707800]Which coolant temp sensor did you replace?
Aftermarket sensor?
Normal operating temp and most thermostats might open around 180, but the fan doesn't kick on until around 203*F. That extra 20 degrees might be what you see?Quote]
Old May 16, 2016
vichonda's Avatar
It is the coolant temp sending sensor. The one that sends the reading to the dash gauge. It is not the coolant temp sensor that sends the reading to the computer. I bought a sensor made in Japan at the Honda Auto Part. The first one bought was a sensor made in China but thinking the same thing went and bought a better one. I also have a 95 civic and bought the same sensor made in Japan and till this date I have not had problems with it. I have a temp laser gun and measured the temp at the thermostat housing next to the temp switch sensor and yes the fan kicks in at about 203-205*F.
Old May 16, 2016
You could monitor voltage on the wire for the sending unit and see if it remains steady while the gauge goes high or if it drops voltage when the gauge goes high.
Old Feb 24, 2020
Charmin122586's Avatar
Charmin122586 is an unknown quantity at this point
I have the same problem with my 1996 Honda Civic cx were u able to figure out the issue
Crimson
Nov 3, 2015 06:53 PM
redrocket87
Nov 1, 2015 07:15 PM
m3mo15
Oct 31, 2015 02:15 PM
Kiotzu
Electrical
Oct 29, 2015 08:56 PM
TaiChi
Canada West
Nov 8, 2001 01:21 AM
