1998 Honda Civic EX AT Starter clicks but doesn't start the engine
1998 Honda Civic EX
I was driving on the highway and my engine started losing power and eventually stopped working. I still had power and got towed.
Been working on it the last two weekends, I've replaced the starter motor, alternator and ignition relay but it still only clicks. there's also rapid clicking behind my gauges when the key is in. I've checked all my fuses, none of them are burnt or broken. Electrical connections are good and my grounds are OK and provide sufficient resistance. Any help is appreciated, thank you.
Also, when the key is in, the dash shows that I'm in park and D4. Brake, battery and oil light all come on.
1998 Honda Civic EX
Re: 1998 Honda Civic EX AT Starter clicks but doesn't start the engine
also, for context, I don't know know what I'm doing and a friend is helping me a lot but we need more perspective
Bad battery/ground/alternator/starter connections. Electricity likes clean shiny metal, and a tight connection.
If you have the crappy battery connections that clamp the ends of the bare wires check there for corrosion. One of my cars wouldn't start because of that. Acted the same as yours
1998 Honda Civic EX
I'm currently away for the next few weeks so I can't do much at the moment.
Does it have an alarm system?
it might ohm out on a meter but the current needed to spin the starter is way more than the meter puts out.
Josh Phillips
Jan 12, 2018 07:45 PM
Pondiki
Nov 9, 2016 07:04 PM
astro303
Feb 28, 2014 08:05 PM
jimwe
Feb 6, 2013 10:28 PM
