Electronics Post your questions about Electronics problems here!
Erratic Speedometer
Old Feb 21, 2022
microserfs's Avatar
microserfs is an unknown quantity at this point
Unhappy Erratic Speedometer
My daughter has a 99 Civic with the automatic transmission. Her speedometer has been acting very erratic. The needle will float and flutter around, sometimes will quickly bounce up or down...it just moves around like it has a mind of its own. It will eventually even out and will read properly...but I don't know if it happens after a set amount of time, or vehicle temperature or distance travelled.
The car WILL hold a constant speed if you set the cruise control. Tested and confirmed this with a GPS speedometer, and set the cruise at 100km/h while the speedo was bouncing all over, and the car held the proper speed.
The trip and odometer do work, and they both move at the same rate while the car is in motion.
So I don't feel that it is the speed sensor in the transmission, but thinking that it might be the speedometer itself. Does anyone have anything else they think it could be, or things to possibly look at? Finding a instument cluster or speedomer in Km/h is also tough...so if anyone has any suggestions that would be appreciated.
Old Feb 21, 2022
Colin42's Avatar
Re: Erratic Speedometer
There was a tsb where the wires for the speedo could get chewed up by the belt. Check that.
Old Feb 23, 2022
microserfs's Avatar
Thank you, I will give that a check this weekend.
farcry88
Electronics
Nov 4, 2021 02:54 PM
honda200192
Apr 5, 2015 09:40 PM
98civic47
Jan 3, 2013 08:06 PM
Grey
Jan 19, 2003 06:19 PM
zetaR
Sep 11, 2002 04:00 AM
