98 civic speedometer going crazy!!!
Old Jul 22, 2012
98civic47's Avatar
98civic47 is an unknown quantity at this point
ok my ek coupe speedomter started to go crazy a couple of days ago. it stops working then goes like if im going 130 mph and up and down alot... is it a ground or something else
Old Jul 22, 2012
Re: 98 civic speedometer going crazy!!!
Is the CEL on?
Is a P0500 code in it?
Does the PCM datalist display the correct road speed (VSS)?
Most just need a speedometer.
A few tests would confirm or deny that.
HTH
Old Jan 3, 2013
voo-doo's Avatar
voo-doo is an unknown quantity at this point
Mine had same problem. I was thinking either sped sensor or speedometer. If you have cruise control and it still holds speed it is not speed sensor. I ended up with a used cluster, and it fixed the problem.
usajags84
15
Aug 19, 2015 03:12 AM
dragonsblood
Apr 27, 2015 12:28 PM
smmahan
Apr 15, 2015 08:17 PM
htowncivicEX
Nov 13, 2001 04:30 PM
colombianDXcivic
Nov 8, 2001 05:26 PM
