Brakes Post your questions about Brakes problems here!
How serious is this small tear in my caliper piston dust boot?
Old Jan 5, 2021
jchristie's Avatar
jchristie is an unknown quantity at this point
Question How serious is this small tear in my caliper piston dust boot?
As you see in the pictures, I found this small tear in a caliper piston boot while replacing pads and rotors on my 2000 DX. I'm trying to figure out how urgent it is that I replace this boot, and/or if I can do so without removing the piston and inner seals and having to bleed brake lines, etc. Not eager to do all of that if I can avoid it, but I really don't know how severe this is and how much damage it is likely to do. Thoughts?
Old Jan 6, 2021
BrotatoChip's Avatar
Super Moderator
Re: How serious is this small tear in my caliper piston dust boot?
The hole will allow dirt/water to get inside which will cause corrosion, eventually the caliper will seize. Impossible to know how long that will take to happen. I don't think you can get the boot off without first removing the caliper piston, but I've honestly never tried.
If you ignore it you will eventually start to notice issues with braking. You could see worse braking performance, car pulling to the other side when braking, or the caliper could start sticking and dragging the brake while driving. Up to you to decide when/how you want to repair.
Old Jan 6, 2021
jchristie's Avatar
Appreciate your feedback. Figure I better get to it sooner than later.
Any insights or tips on the process of replacing the boot, inspecting the piston, replacing seals, etc? Honestly I haven't done any more invasive brake work than pads and rotors, so would be my first time opening up the brake lines/hydraulic system etc. I don't think I'd be in way over my head, but have some research ahead of me before I go pulling all that apart. Any knowledge you have of what to watch out for would be golden.
Thanks.
Old Jan 6, 2021
Colin42's Avatar
I would just install 2 new calipers
Old Jan 7, 2021
Super Moderator
Agree. Could be rust already starting inside. Calipers are fairly cheap, might as well replace them and not worry for years to come.
joenobodyyet
Brakes
Nov 10, 2020 09:53 PM
threeoten
May 9, 2016 06:42 PM
TRIZ
Brakes DIY
Jul 31, 2015 09:27 AM
Daniel420
May 4, 2005 02:48 PM
bluericeburna2k2
Mar 30, 2004 07:06 PM
