Replacing trim between windows and doors [solved]
Old Jun 21, 2022
Dutchstarr's Avatar
Dutchstarr is an unknown quantity at this point
2002 Civic LX, 150kish miles
Clear Coat Failure is on fleek so I am going to get a repaint, but also wanted to address the crappy looking exterior trim between windows and doors. See photos. A friend of mine dressed them up a few years ago with some kind of plasti-dip stuff but it has since peeled off.
My question: is there a simple part-replacement fix for this? Or some other kind of longer-lasting solution? Thanks
Old Jun 21, 2022
re: Replacing trim between windows and doors [solved]
not a customization, rather a mechanical issue, moving to proper location of the forums
Old Jun 21, 2022
Colin42's Avatar
Its stainless underneath, peel it all off and make the car look fancier
Old Jun 21, 2022
SIngram's Avatar
SIngram is an unknown quantity at this point
If it is stainless, why do they bother putting the weather stripping on it?
It could be to protect the glass or it might be some sort of heat sink.
I would not recommend ripping anything off a car without knowing for sure that it serves no purpose.
Old Jun 21, 2022
he is telling to remove the paint the op's friend put in there, not the piece... read again
Old Jun 21, 2022
Colin42's Avatar
It makes the window look slightly bigger/blend into the body panels. Seen plenty of cars in my area with all that black peeled off
Old Jun 21, 2022
for those unaware, plast-dip is a temporary paint. It can be peeled off by hand the next day.
you feel like having a yellow car tomorrow? paint it with plast-dip. Next week, peel off the yellow paint.
it can also start peeling off by itself, it is temp, after all
Old Jun 22, 2022
BrotatoChip's Avatar
Super Moderator
I replaced those trim pieces on my coupe like 8 years ago because it looked similar.
Old Jun 22, 2022
Dutchstarr's Avatar
Thanks, do you remember what the trim piece was called? Been looking all over the place and can’t identify the part number…
Old Jun 22, 2022
https://www.civicforums.com/forums/1...retailers.html
Old Jun 22, 2022
Super Moderator
Using a site like HondaPartsNow.com, you can find these pieces in "Interior / Bumper" > "Molding - Protector". Reference parts 1 and 4 for the front doors, 7 and 9 for the rears.
Old Jun 23, 2022
123Krash's Avatar
123Krash is an unknown quantity at this point
I had an '01 Civic, same issue.. I pulled them off, peeled that balck off, light sanded and rattle can sprayed with a rust-oleum flat black lasted fine for another 6 years til I traded the car for an '12.
Old Jul 23, 2022
1190405's Avatar
1190405 is an unknown quantity at this point
Can they be poped off without removing the side-view mirrors? I am having this issue with my 01 LX as well and it is currently the main/biggest eyesore. I don't feel like spending $200 or so on the replacement pieces for now so I am looking for the easiest solution.
I'm thinking about either peeling off all the black and leaving it as-is for that chrome-like appearance or peeling off all the black and spraying it with black Plasti-dip.
Or, if it is really that easy to remove, do the above but with the piece off the car so I don't have to worry about masking off/overspray issues.
Old Jul 24, 2022
123Krash's Avatar
Been a while but I think it was kind of esay, and no the mirror was not removed in the process...
sdnomad
Electronics
21
May 30, 2023 11:46 AM
Takato
Aug 27, 2021 10:19 AM
Njr
Exterior
Jul 15, 2021 12:48 PM
Majarvis
Dec 22, 2005 11:29 PM
xzykotic
Jan 16, 2003 12:26 PM
