Sprung driver's door - lots of wind noise now
Old Jul 17, 2020
CivicHybrid03's Avatar
CivicHybrid03 is an unknown quantity at this point
Unhappy Sprung driver's door - lots of wind noise now
I was working on my Civic in the driveway, sun was hot so I moved it into the shade. (air cleaner box was off, so I was pushing it)
I had the door open and it started to roll, (backwards) but I jumped in too late to stop it before the door contacted a tree. There was a CRACK.
Everything looks fine, but the door sort of 'pops' open a couple inches when I pull the door handle. Also there is a LOT of wind noise - the faster I go the worse it is - of course.
Any ideas how I can fix this? Is there something inside the door that I can bend back to the correct configuration? I have no problem pulling the door panel.
This noise is unacceptable.
Thanks!
Old Jul 17, 2020
BrotatoChip's Avatar
Super Moderator
Re: Sprung driver's door - lots of wind noise now
Compare the driver/passenger mounting hinges. Find out what is bent then you will be able to fix it.
Old Jul 17, 2020
Colin42's Avatar
Hopefully it's just the hinges and not the entire door
Old Jul 17, 2020
Chilton and Haynes manuals always say installation is the reverse of disassembly. Simple.
So....I guess that means you need to un-hit the tree. Simple.
It could have bent the post that holds the hinges, it could have bent the door, and more
A decent bodyshop should be able to fix it.
Old Jul 19, 2020
Smile Re: Sprung driver's door - lots of wind noise now
I think the door is fine; I believe the problem is in the hinge area. Looks like the hinge halves mounted to the body may have pulled out a bit.
Not looking to pay body shop prices; I am going to try fixing it myself - hopefully not making it worse.
Thanks!
Old Oct 10, 2020
Talking Re: Sprung driver's door - lots of wind noise now
Update - better late than never.
A friend and I pulled the door and tapped in the body side door hinge halves a bit. That didn't quite do it, so we used a big bar to tweak the door/window frame some.
Took about an hour - all good - no more water leaks or wind noise. The latch makes a tad more contact than it should when closing the door, so I'll play with that later.
EarleD
Mar 31, 2014 07:35 PM
H-Ian
17
Apr 16, 2010 07:12 PM
scooty
May 14, 2009 08:11 PM
civicplaya
Buy, Sell, & Trade - Archive
Jan 23, 2009 07:35 PM
JRHAWK9
Jan 27, 2005 09:15 PM
