Fuel fill door won't open
Old Jan 24, 2006
djlucas82's Avatar
djlucas82 is an unknown quantity at this point
I have a 2001 EX and am unable to open the fuel fill door. I push the release latch down and it won't pop open. I also can pry it open with a screwdriver. I searched the forums and didn't find any posts on this topic. Can anyone help me out? Is there an easy fix or do I need to take this into the shop?
Old Jan 24, 2006
RHCP0801's Avatar
i have the same problem yet i still havent gotten it fixed cause im lazy and dont feel like dealing with the dealer cause i have aftermarket parts. There is still a way to open it, open the trunk peel back the carpet on the left side where the gas tank is and reach all the way back and you will feel a little black plastic **** thing, turn it while pulling towards you and when you pull it out the door should open up, to insert the black thing back in just line up the two tabs with the openings on the hole and turn the **** till the tabs are horizontal, that should do it, if you have any problem just ask. You will have to go to the dealer to get it fixed
Old Feb 6, 2006
djlucas82's Avatar
Thanks rhcp0801 for the report. I ended up getting it fixed (my trunk is too messy to open every time I need to fill up). But I'm glad I know how to open it in a pinch.
Old Nov 9, 2006
teammo's Avatar
teammo is an unknown quantity at this point
there is a easy fix available for the fuel door release. You can purchase a repair kit for the fuel door cable here at http://www.fueldoorfix.com I hope this helps you out!
Old Nov 12, 2006
_SKIN_'s Avatar
Member
_SKIN_ is an unknown quantity at this point
Rep +1... Good info for a guy with a broken fuel door.
Old Nov 14, 2006
teammo's Avatar
Ya they work great !
Old Nov 14, 2006
thewal's Avatar
thewal will become famous soon enough
I also had the same problem. I had to replace the release cable that runs from the release latch to the trunk. Common problem with Civics. the plastic that holds the cable to the latch breaks very easy.
Old Dec 20, 2006
feet_'s Avatar
feet_ is an unknown quantity at this point
yup just picked one up!
guys my old neighbour that invented the fix.!
good guy!
Old Dec 20, 2006
mr.rowdy's Avatar
mr.rowdy is an unknown quantity at this point
That works
MamaBear2015
May 18, 2015 07:37 PM
maaronia
May 14, 2015 10:46 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
Juancho007
Dec 16, 2001 01:02 PM
TopFuel
Exterior
Nov 13, 2001 07:05 PM
