Help...cruise control module?
Hey All, I have a 2003 Coupe Ex 5spd, with cruise control issues. It's not the usual pedal switch bumpers this time. It won't engage at all, I have power coming in and out of the main switch, have continuity on both clutch and brake switches, so I'm thinking it's the cruise control module (auto cruise module), the problem is that I can't find it! The manual I was looking at said it was under the dash pretty close to the main switch, but I don't see it anywhere up there. Plus I think the manual was for another country, possibly Canadian, I don't know, just noticed that the shifter was different. Can someone please point me in the right direction?
Thanks,
Pete
Thanks,
Pete
Re: Help...cruise control module?
Coupe and Sedan have different cruise systems.
Coupe has the cruise control unit in the actuator.
Check that the cables have not come unattached. https://www.civicforums.com/forums/3...nsmission.html
Figured it out Y'all! Thanks for all the help! So, I finally found an applicable manual that I could download, and started running through the wiring checks at the actuator connector under the hood and found out the problem was with the brake switch not depressing fully. It was going in enough to shut off the brake lights, but not enough to supply the 12V to the cruise system. I guess the last time I replaced the little bumper, I didn't use the exact correct one, it was a little softer rubber and the switch actually made a little indention in it over time. And btw, y'all are right the cruise system in the coupe and sedan is different...(which makes no sense to me, but whatever!).
Thanks Again!
Thanks Again!
I laid in the floorboard for half a day searching for the module. THANK YOU for letting me know it is in the actuator.
Pete - would you post a link to the manual with the actuator checks ?
It is available in the service manual. Check the last few posts in the thread below for a download link.
https://www.civicforums.com/forums/1...pdated-13.html
Seraph21
May 15, 2017 08:52 PM
honkeydonkey
Jun 23, 2014 07:43 PM
ivanjunge
Oct 15, 2012 06:01 AM
