General Post issues, questions that are not in the other sub-forums
Ignition and steering wheel locked.
Old Nov 11, 2019
Seth Jeannette's Avatar
Seth Jeannette is an unknown quantity at this point
Ok here it goes!!! My 03 honda civic ex coupe 1.7l has been sitting for quite some time now. My battery has died in the car. I jumped my battery and turned my car on it was fine ignition worked fine turning on and off. I left my car running for a couple hours so that my batyery can keep a good charge. When i shut my car off the key moved smoothly like it should. BUT!!!! when i went to tirn the key back to start my car it would not turn. It wiggles a bit and my steering wheel is locked. Now i know about wiggling the steering wheel and turning the key at the same time. But the problem is thay is not working at all. Is there anything you guys can think of that i may need to do?? If worst case scenario could i bang out my ignition and use a screw driver to turn my car on??
Old Nov 12, 2019
BrotatoChip's Avatar
Super Moderator
Re: Ignition and steering wheel locked.
No. You should be able to remove pins from the tumbler so that anything will turn it. But you will still have to use the original key or the immobilizer will not allow the engine to start.
Old Nov 12, 2019
How do i go about removing the tumblers
Old Nov 12, 2019
Super Moderator
I have never done this and the service manual doesn't show anything either.
Another thing you could try is spraying some WD-40 in the ignition then slide your key in and out a few times. It may help loosen stuff up and get it to work again.
Old Nov 12, 2019
So, just to recap. You've pulled the wheel in the direction in which it's locked (not just wiggled) and tried to turn the key, yes?
CivicallyMinded
Dec 21, 2007 01:02 AM
slicksivik
Jan 7, 2007 12:08 AM
rokenrolcivic
Jan 31, 2004 10:25 PM
gqsang
Mar 28, 2002 04:15 PM
Diznavis
Mar 13, 2002 05:18 PM
