General Post issues, questions that are not in the other sub-forums
She died while driving
Old Apr 13, 2019
crazyone64's Avatar
crazyone64 is an unknown quantity at this point
What does it mean when the cars fuel pump does not prime - the car cranks but doesn't start.
The fuel pump fuse is good and this is the first time it's happened. Haven't been able to start it since.
I'm leaning towards - check if the fuel pump is getting power, and if it is, replace fuel pump and filter.
What do you think?
I plugged in the OBD2 scanner - nothing
Old Apr 14, 2019
mikey1's Avatar
Re: She died while driving
check your timing belt....might have snapped
Old Apr 14, 2019
crazyone64's Avatar
Thanks for suggestion, belt is fine.
Old Apr 14, 2019
Slumpertcivic's Avatar
There is a simple relay behind the glove box that controls power to the fuel pump.
Make a basic jumper out of a paper clip and see if you hear the fuel pump spin up.
Old Apr 15, 2019
For me, a Honda fuel pump is never the first suspect.
Old Apr 15, 2019
crazyone64's Avatar
Thanks for the replies,
The fuel pump has been priming and i started it a few times - in the last 24 hours.
Seems to be intermittent which makes me think that i'd need another tow when it happens again.
Old Apr 15, 2019
Calling a tow truck to drag the car to work and back seems a bit redundant and inefficient....., a taxi or uber might be cheaper.
Very efficient: Order a pizza to be delivered to work and catch a ride with the delivery driver
Save tow fees: Don't drive your car past the end of the driveway until it's fixed
You might toss the main and pump relays at it? Those are probably cheaper than a tow truck
Would be nice to actually be able to diagnose and prove exactly what the true problem is, not just guess and toss parts
Old Apr 16, 2019
mikey1's Avatar
my next suspect would be the cam or crank sensor
Old Apr 16, 2019
piano55man's Avatar
piano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of light
don't mean to be a sarcastic ***...but have you checked your fuel level?
Redhead818
Engine start problems
Jul 1, 2018 04:15 PM
boostem2
Jan 20, 2013 03:27 PM
boostem2
Dec 4, 2011 05:56 PM
Cleft_Asunder
Dec 26, 2010 09:25 AM
cosmo
Aug 11, 2004 05:00 PM
