Fuel Pump Problem Fix
Old Dec 4, 2011
boostem2's Avatar
boostem2 is an unknown quantity at this point
hey whats up, i gotta possible fuel pump situation. I recently got a brand new walbro fuel pump (gss342) and figured it was a half an hour job. I installed the pump, and went to start my car when it wouldnt turn over at all. It would just crank, crank, and crank, no putter as if it was trying. I checked for flow at the tank and at the fuel rail and both had pressure during ignition. (position 2) Once i start to crank, the pump turns off. I decided to return to the factory pump which was good. My car started and ran with stock pump for a while, then stalled and wouldnt start back up. Ive checked fuel pump fuse which was good, removed and put back in the blue relay behind the glovebox. Only once the car has been sitting for sometime does it start back up and stay running, but once it turns off nothing. Any help guys i would really appreciate the input. i gotta get to work and im running out of ideas....
CarStuff
Dec 6, 2020 12:52 PM
Jonnie.
Jan 13, 2019 11:21 AM
Trav_02civic
Engine start problems
Apr 23, 2015 08:57 AM
