General Post issues, questions that are not in the other sub-forums
Maintenance Required at 132K Miles ???
Old Jan 8, 2014
mrohitredd's Avatar
mrohitredd is an unknown quantity at this point
I bought a 2002 LX about 15 days ago, after crashing my old one
The car looks quite & ok so far... But I want to do all the possible required maintenance at 132K miles...
Right now, (I'll have to observe this a little closer) i see the car temp is climbing a bit... (felt weird in a freezing climate)
Is there a coolant flush or something, that needs to be done around this milage ?
Can someone please give me a list of maintenance work needed at this age of the car... Thanks in advance...
Old Jan 9, 2014
Stock 99's Avatar
Re: Maintenance Required at 132K Miles ???
https://www.civicforums.com/forums/3...reference.html
I'm not going to say it's a head gasket but it seems to be one of the most common reasons for overheating in a 7th gen.
Old Jan 9, 2014
mikey1's Avatar
if the timing belt has not been changed then you are way overdue on that, that would be my number one priority,
check coolant level in rad and overflow bottle, if they are both at acceptable levels and your still overheating or getting "hot" then chances are your head gasket is blown and you now know why the previous owner ditched this car,
could also be a faulty thermostat but my bet would be placed on the head gasket,
99% of the time these engines get hot and overheat the head gasket is to blame.....good luck because i think your going to need it, that and a whole lot of $$$$$$$
Old Jan 9, 2014
mrohitredd's Avatar
Can I check before changing it ? Or monitor the gauge on the dash is the only way ?
Old Jan 9, 2014
crxmanpat's Avatar
Pusher Jets Rule!
crxmanpat has a spectacular aura aboutcrxmanpat has a spectacular aura about
You can check cylinder compression, and/or do a leakdown test, but these won't always positively identify a blown headgasket. Is there any evidence of coolant being splashed around on the inside of the engine bay, especially near the overflow bottle? Do you ever smell coolant, even if just a little?
Based on the age/mileage of the car, the book says do the following for 108K/120K miles:
Replace Fuel Filter (every 24K)
Replace Spark Plugs (every 24K)
Replace timing belt and inspect water pump (every 60K)
Inspect and adjust (replace as necessary) drive belts (every 24K)
Replace engine coolant
Replace transmission fluid
Inspect brakes
Replace brake fluid
Check barking brake adjustment
Old Jan 11, 2014
check method is in the first post... did you read the link?
did i mention to read the link thread?
Old Jan 13, 2014
mrohitredd's Avatar
was away & saw these over the phone... missed the link (main thread)... Thanks all... i'll give this a try...
Old Jan 13, 2014
:d
mattdoc
Mar 14, 2017 12:10 PM
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
LOST
Jan 28, 2002 01:01 PM
Aznnp77
Jan 6, 2002 08:41 PM
