Bluetooth Post information/questions/Issues about Bluetooth connection here.
Bluetooth Phone Issue
Old Jan 12, 2020
Tin Tran's Avatar
Tin Tran is an unknown quantity at this point
Question Bluetooth Phone Issue
Hello everyone,
I have a 2012 Civic and my factory radio recently started to do something weird. My phone connects fine via bluetooth to the car and play music perfectly. However, when I receive phone calls the sound quality becomes really fuzzy and really quiet. I have to crank the volume all the way up on the phone and the car to hear anything but that only serves to make it even more fuzzy to the point of not being able to understand anything at all. After some troubleshooting and investigation it appears that when the radio switches to phone mode the sound for some reason only comes out of the front door speakers and nothing else. This happened out of nowhere and I've checked all the settings but can't find anything wrong. I've also taken the head unit out to ensure everything is securely plugged in but still nothing.
Any help or insight is appreciated.
Thanks
Old Jan 12, 2020
GolNat's Avatar
Prelude Owner
Re: Bluetooth Phone Issue
Have you tried other phones to rule out a phone issue?
When you pulled the radio out did you disconnect power? You can try to reset the radio and see what happens.
Old Jan 12, 2020
Tin Tran's Avatar
Those are both great ideas! I'll try both and report back.
Thanks!!!
Old Jan 24, 2020
Tin Tran's Avatar
Just tried both options with no luck.
I even unplugged the actual car battery to reset everything but still nothing!
This is really starting to get annoying so any other ideas on how to fix this would be greatly appreciated.
Thanks
Old Jan 25, 2020
GolNat's Avatar
Prelude Owner
It could be something simple like the bluetooth module or radio but further troubleshooting is needed. They sell replacements but not sure if that is the issue or not. You can take it to the dealer or independent mechanic that does that sort of work but for the cost of that I would just update the radio to a newer one personally.
Old Jan 25, 2020
Tin Tran's Avatar
Hi Everyone,
After more troubleshooting I've now also noticed that the same audio issue happens when the "phone setup" instructions are playing. This leads me to believe there is something wrong with the entire "phone" option in general.
Again, this was something that happened once or twice before but would resolve itself. However, it sure does seem like it's here to stay now.
Might have to just live with it because getting this fixed or replaced professionally seems like more trouble than it's worth.
Thanks
ChrisCivic97
Electrical
May 17, 2020 08:00 PM
Chd61584
Aug 26, 2019 04:54 AM
Mr Waffles
Bluetooth
Jun 26, 2016 02:06 PM
Putonyourcans
May 31, 2014 08:30 PM
NoLeadEmSoMuch
Mar 20, 2008 08:55 PM
