‘12 civic manual key entry
Old Mar 28, 2021
Samuel Borg's Avatar
Samuel Borg is an unknown quantity at this point
I just bought a 2012 Honda civic and the key fob works for everything except using the physical key to unlock the drivers side door. It can start the car though. I was thinking it was the actual lock mechanism?
Old Mar 29, 2021
BrotatoChip's Avatar
Super Moderator
Re: ‘12 civic manual key entry
The fob unlocks all doors except the driver's door? I would guess the door lock actuator is bad.
Old Mar 29, 2021
Colin42's Avatar
Key cylinder might be seized from lack of use
Old Mar 29, 2021
Ill try lubricating the lock and go from there. Any recommendations for a certain lube brand?
Old Mar 29, 2021
Colin42's Avatar
Brand doesn't matter, either graphite lube, or some something like fluid film
Old Apr 1, 2021
So I used some graphite based lube and a tiny bit of wd40. Barely enough IMO but I assumed it wasnt good for locks. Its still stuck and my key cant turn it at all. So, worse case I have to buy a new key cylinder? Or is there something else I could try? I let it sit and tried turning the key for a bit to move the graphite but it still hasnt budged.
Old Apr 17, 2021
newoldcar's Avatar
newoldcar is an unknown quantity at this point
bump
my front driver side door lock also does not work. The will not turn, tried lubricants.
Only option to replace the cylinder and have two keys? One to open, one to start?
Old Apr 17, 2021
Colin42's Avatar
Originally Posted by newoldcar
bump
That's the cheapest way to do it, can also retumble the new door lock to match the ignition
SpeedReeeser516
Apr 3, 2018 11:02 PM
sijen
Jan 7, 2013 05:41 PM
somegaveall
Sep 12, 2009 07:15 PM
roger t
Feb 25, 2009 07:50 PM
shipprs
Feb 4, 2009 08:23 PM
