Electronics Post information/questions/Issues about Electronic parts here.
Rear lights turning off problem
Old May 26, 2023
Civic-06's Avatar
Civic-06 is an unknown quantity at this point
Hi everyone!
I have an odd problem with Honda Civic 2006 Hatchback. When lights are on normal "Off" position, all lights works as intended (start and shut automatically with engine).
Now, when I switch to even parking light or long light mode, all rear lights goes off. Same with speed meter etc lights. Head lights works normally. Turning back to default "Off" position, all lights works normally.
Anyone have a clue what could cause this? If a fuse problem, where can I find the correct one?
Old May 26, 2023
Colin42's Avatar
Re: Rear lights turning off problem
The taillight is different than the brake light, the bulbs have 2 filaments. Have you checked the bulbs? Dimmer on the gauge lights might be low.
Old May 26, 2023
Civic-06's Avatar
Bulbs are fine, and yes I ment taillights goes off. Braking lights still work with other options aswell.
Old May 26, 2023
Colin42's Avatar
So the taillights are on with the switch off?
Is there an aftermarket alarm/remote start?
Old May 26, 2023
Civic-06's Avatar
Yes, taillights works correctly only when the switch is off. Light alarm works normally too when shutting down the engine and the switch is half or on.
HUD Meter (speedometer etc) lights goes off too when switching half or on, but goes on when the switch is off.
Old May 26, 2023
BrotatoChip's Avatar
Super Moderator
Oh boy do you have some issues. Obviously, nothing should be on with the switch in the off position. Maybe it's a faulty headlight switch.
Old May 28, 2023
Civic-06's Avatar
Most newer cars switch lights on automatically when the car is started. Been since 1990-century.
Old May 28, 2023
not really. Civics in US usually did not have DRL's until the 2006 models
Old May 28, 2023
Colin42's Avatar
Not the taillights. DRL turns on usually the high beam at half power.
Old May 29, 2023
Civic-06's Avatar
Anyone have a clue where the automatic light fuse is in Civic 2006?
Old May 30, 2023
Super Moderator
Only if you have it in auto mode......there is still a headlight switch to turn them on/off.
Old May 30, 2023
Civic-06's Avatar
Yeah, in parking mode between "on" and "off" Euro cars shuts the headlights, but the parking lights stay put. There is absolutely no way to shut down all the lights when engine running at all.
This issue aint with headlights but rear ones.
Off topic: If you don't have the Civic Hatchback version in U.S, it is really odd, 'cause IMO hatchback is the most beautiful version of Civic ever
Old May 30, 2023
I would take to a dealer, might be an issue with the DRL module
Old Jun 16, 2023
Civic-06's Avatar
They told me in the service that it could be automatic light fuse. I can't find the fuse from the manual. Anyone can hint me which one could it be?
Old Jun 16, 2023
37... that is the official name, DRL.
Old Jun 19, 2023
Civic-06's Avatar
THANK YOU! Will check it out when I'm at the car next time, but I think this is it!
ngrome
Apr 28, 2013 09:36 PM
Black_EM2
Aug 11, 2010 11:24 PM
eklipz
Feb 25, 2005 10:50 AM
PeArlHoNdA
Mar 27, 2002 01:53 PM
