Electronics Post information/questions/Issues about Electronic parts here.
2014 Civic EX Gas Cap Loose Message
Old May 25, 2022
Timbogates's Avatar
Timbogates is an unknown quantity at this point
Arrow 2014 Civic EX Gas Cap Loose Message
My 2014 has been getting the message on my small screen display the Gas Cap is loose. I have cut the car off and retightened the Cap a few times and I still get the message. The car has been sitting not cranked for about 3 days and the tank is full. Suggestions please and list a few. I have been thinking that maybe remove the battery cables is one option but is there a few more first. Thanks
Old May 25, 2022
BrotatoChip's Avatar
Super Moderator
Re: 2014 Civic EX Gas Cap Loose Message
Could be a fault gas cap. The message means it detects a leak in the fuel tank, not a gas leak but vapors.
Old Sep 14, 2022
Atarian's Avatar
Atarian is an unknown quantity at this point
Gross evap system leak code is probably stored, at least as a pending code. Do you have a code reader?
Probably the canister vent valve or purge valve. Both are relatively cheap.
Old Sep 23, 2022
Atarian's Avatar
You can try a gas cap - that's very easy. If it doesn't work just take it back. From recollection *only* so may not be right, the evap test only runs when the fuel tank is 1/4 to 3/4 full. There's also some temperature parameters, like not below zero or over 120 degrees (those are examples). This time of year no matter where you are that should not be a problem.
I guess you could also make sure the sealing surface on the filler neck and the gas cap are nice and clean. If cleaning or a new gas cap takes care of the problem the message will go away by itself after a few drive cycles. If it remains that was not the problem. Also if you have access to a code reader the code will go from "active" to "history".
I can't remember the last time I saw this message that it was actually the gas cap.
fstjohn
General 7th Gen
Nov 5, 2018 03:18 PM
Brian1037
Oct 16, 2010 02:05 PM
White05EXSE
Jul 16, 2005 12:28 PM
streetglower
Aug 8, 2004 05:33 PM
Forum Bot
Exterior DIY
May 17, 2004 07:25 PM
