Electronics Post information/questions/Issues about Electronic parts here.
09 Civic non-start after repairs [solved]
Old Jul 7, 2021
caarce's Avatar
caarce is an unknown quantity at this point
Question 09 Civic non-start after repairs [solved]
Hello, have been working on a civic that was sitting for a while. Had it towed to a shop, they gave it a new battery and did some minor maintenance, was able to drive it home. Car wouldn't start a few weeks later, was turning over but would stall out. Changed the spark plugs, nothing. Got OBD code said EVAP purge valve was malfunctioning, replaced it and it started right up. Drove it around for about 2 days then won't start again like before. Car has battery life, and turns but stalls out quickly. Not getting anymore OBD codes.
Any suggestions?
Old Jul 7, 2021
Colin42's Avatar
re: 09 Civic non-start after repairs [solved]
Check battery and ground connections, check that everything is plugged in
Old Jul 8, 2021
and fuses?
Old Jul 8, 2021
caarce's Avatar
SOLVED
I found the problem: immobilizer was causing shutoff due to rejecting 2 of my 3 keys. FYI if you see green key light blinking for more than a few seconds after turning key to ON(II) position it means there is an issue with the immobilizer. In this case 2 of my keys are bad, not the lock.
Old Jul 8, 2021
Colin42's Avatar
Re: 09 Civic non-start after repairs [solved]
Glad you got it figured out, for future reference let us know if any dash lights are on
leok99
Nov 2, 2020 12:32 PM
WKD DRGN
Mar 9, 2016 02:06 PM
zanjero
Feb 23, 2015 12:31 PM
mayfly36
Jan 7, 2013 01:15 PM
dancer68
Jun 21, 2010 10:55 AM
