just installed my intake and now my accelerates is slower
Old May 20, 2003
03CivicEX03's Avatar
03CivicEX03 should not be trusted03CivicEX03 should not be trusted
I just installed my aem intake and now my accelerates is slower then before. It seem like my gas pedal is loose not as tight/hard use to be. I don't know is it me or it seem my gas pedal is shorter? help help!
Old May 20, 2003
NorrinRadd's Avatar
NorrinRadd is an unknown quantity at this point
In general if you installed an SRI then you will accelerate slower in the low-end rpms and have more power in the high-end, while CAI will give you opposite results.
Old May 20, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
Did you reset your computer? Pull the battery cable, then turn the key to discharge the system. Let the car sit for 10 minutes, hook it back up and let the engine idle for 10 minutes without touching the gas pedal at all. That should re-set the computer to the new increase in air flow. Any of the pipe/cone filter intakes are going to take out low end power since you took the resonator out.
Old May 21, 2003
Travii's Avatar
Travii is an unknown quantity at this point
Driving around also resets your ecu to the new hardware, this method only does it faster.
Old May 21, 2003
R3DL1N3's Avatar
yeah, its basically a breaking in process for your intake. most all bolt on mods require you to break your **** in
Old May 21, 2003
Jap-Euro Fusion
Well if you read, it says he JUST installed it... therefore the computer would not have the time reset, and would account for the engine running like ****. It takes a couple hundred miles for the car to adjust on its own.
jtdunn4life
Oct 27, 2015 03:33 AM
Reverb2005
Jun 26, 2015 06:22 PM
Kyrian
Jun 26, 2015 11:48 AM
carid
Apr 30, 2015 07:00 AM
kanin247
Bolt-on Engine Performance
Apr 25, 2015 05:44 AM
