Engine Shaking
Old Apr 24, 2003
littlecow's Avatar
littlecow is an unknown quantity at this point
Engine Shaking
Hey tech guys out there, I noticed that my car has been shaking pretty noticeably after the engine has been warmed up and I am sitting at a stop. I popped the hood to take a peek and notice that my engine is shaking pretty good. This has gotten me pretty worried. So any preliminary diagnosis? 36000 miles on car.
Old Apr 24, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
I think this is a known problem. Take it to the dealer.
BTW, this should be in Problems, not tech stuff.
Old Apr 24, 2003
spookini's Avatar
spookini is an unknown quantity at this point
Bad rubber bushings in the engine mounts? That's my guess.
Old Apr 24, 2003
LikeWEEEEEEEEEE's Avatar
LikeWEEEEEEEEEE is an unknown quantity at this point
i would say its your engine mounts
Old Apr 27, 2003
SomeDoodToo's Avatar
SomeDoodToo will become famous soon enoughSomeDoodToo will become famous soon enough
ya i have had this happen since day one and i only have 4k on mine
Old May 8, 2003
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
Same here. Ever since I bought it. I now have 8000 miles. They said they will look at it after the struts are replaced.
Old May 8, 2003
Zigen1's Avatar
Zigen1 is an unknown quantity at this point
I think you have the same problem as the other 2k1 guys who have idling problems. Definitely not related to the bushing etc.
Old May 9, 2003
iluvbritney's Avatar
iluvbritney is an unknown quantity at this point
after i rev, rpm goes down and it shakes for a sec...
Old May 9, 2003
ak's Avatar
ak
Retired Mod
ak can only hope to improve
Same shaking... i'm guessing that it is because the engine is getting older?
Perhaps needs tuning?
Old May 9, 2003
Boosted2k2's Avatar
I only have 8000 miles though... this has been happening since I bought the car.
Old May 9, 2003
cracked motor mount
Old May 12, 2003
Boosted2k2's Avatar
I would think if it were the motor mount it would be more noticeable and more of a constant shake... this isn't though. It has no rhythm at all, and it only happens at idle.
Old May 13, 2003
oh my bad, its the ecm that is allowing the revs to fall too far during idle.
Old May 13, 2003
solar's Avatar
solar is an unknown quantity at this point
And you figured this out how? It could be many things, clogged injectors, bad plugs, crappy gas, airflow sensor, coil voltage, fuel filter, etc. etc. Its impossible to properly diagnois his problem without looking at it first hand and doing a code scan.
Its possible its a ECU, but if it is its just a good guess. He needs to take into a shop to have it properly diagnoised.
Old May 13, 2003
PicCoLoboi02's Avatar
PicCoLoboi02 is on a distinguished road
i'm not sure but it could be the timing belts being too tight? does it rattle and have a kind of loud sound to it.
Old May 13, 2003
Boosted2k2's Avatar
there is no sound at all. It's not something you see either. You just feel it. I can feel it in my seat sometimes at idle. I opened the hood at idle and put some weight on the engine and you can definately feel it. I don't use crappy gas btw. I don't think my injectors would be clogged from the get go... or the fuel filter. It's possible, but I don't think it's likely. Honda is supposed to take a look at it after they replace my struts though. I'll post back here when I find out.
Old May 14, 2003
solar's Avatar
I have a slight vibration from my engine, but not enough to make me worry, but the last to Hondas I owned you couldn't even tell the car was running.
Old May 14, 2003
civicdude's Avatar
Mine did it since new, but I finally got it fixed.....So now I dont have the problem anymore.....I had to trade the car in to get rid of the problem....lol. Honda tried to fix it 3 times but it kept coming back amongst all the other first year problems. I finally got fed up and I wont have the problems anymore as of this saturday....I will have a new car to drive.
bravo79
Suspension
18
Feb 10, 2022 09:52 PM
blaketippett
May 29, 2015 08:02 AM
RickyRocket
Nov 30, 2001 10:14 AM
Hobby2K
Bolt-on Engine Performance
Nov 9, 2001 04:08 PM
colombianDXcivic
Nov 8, 2001 05:26 PM
