Check Engine Light
Old Apr 6, 2003
andrew886's Avatar
andrew886 is an unknown quantity at this point
Check Engine Light
I was driving home yesterday and my check engine light came on. Now i've had the check maintenance light come on and thats because of oil change and what not. However when i looked this one up in the manuel it said it has something to do with the emissions system. I'd put gas in several days before so i confirmed to make sure my gas cap was on tight(b/c manuel referenced that as a problem), also recently i had a bad cat replaced. What could it possibly be that is causing this? Any ideas to save me from taking it to the dealer?
Old Apr 6, 2003
cwick187's Avatar
cwick187 is an unknown quantity at this point
Maybe it's a bad sensor now..just take it to the dealer and have them hook it up to the comp.
Old Apr 6, 2003
XxSoVeReiGNxX's Avatar
Yeah I had that happen to me a while back. Every time I turned my car on, it would flash a certain number of times. But The dealer knows what to do. Just wait until your next checkup. I did a minor maintenance checkup at 16,000 (more than just an oil change, basically prepping my car for warmer weather) and it stopped afterward. The light goes off probably as a reminder for a checkupor like you said, oil change. There's no sense in bringing in your car just to get that light checked-up, you'd be wasting your money and they'd gladly take it from you.
Old Apr 6, 2003
RoadRunner's Avatar
how many miles do you have on your car, is it past 10,000. Because after you pass that amount the light comes on and stays on. There is instructions in your car manual on how to rest that light.
Old Apr 7, 2003
SLeePeR012's Avatar
SLeePeR012 is an unknown quantity at this point
Take it to Honda asap if its the check engine. The maintaince is no biggie.
Old Apr 7, 2003
BlueFlame's Avatar
BlueFlame is an unknown quantity at this point
ok, he said it wasn't flashing when you turn the engine on - that's a simple warning reminding you to get your oil changed and get a tune up - easilly corrected by pushing in on the mileage reset button, starting the car and holding it for about 30 seconds to be safe, and then turn the car off. Next time you turn the car on, the maintenance light won't blink ..
However, if it just came on and stayed on while you were driving, then it's probably like you said, some emissions problem - after all you looked it up in the manual and would know. Thank goodness there are still SOME people who do the work and don't just post simple problems without at least making some amount of effort.
ANYways, if it's something more serious, like a bad cat-converter that you mentioned, the best idea would be to take it in and have the dealer check it out.
Good luck with that man, hope it's nothing too serious or expensive ...
Old Apr 7, 2003
robbclark1's Avatar
Retired suspension supermod.
some of you have to read before you post. He said CHECK ENGINE LIGHT not MAINTENANCE LIGHT!!
If you don't want to take it to Honda right away and the car sounds like it is running fine, you can try to reset your ECU by disconnecting your battery for about 10min. Sometimes if the a code is thrown for the gas cap thing, it might not go off. Try resetting your ECU first and if it still comes on, take it to honda for a full ECU code check.
Old Apr 7, 2003
CivicMonkey's Avatar
CivicMonkey is an unknown quantity at this point
I had the same problem with my car,
take it to the dealership to get it checked out, cuz it may still be underwarranty. My problem was some thing wasnt sealed tight enuf and liquid in a pipe was causing the light to come on. He said it was the manufacturers fault. So check it with the dealership
Old Apr 7, 2003
NeonImpact's Avatar
Forum Sponsor
thanks for clearing that up to everyone rob..
yes, the best thing to do is take it to the dealer..
Old Apr 8, 2003
andrew886's Avatar
since posting i wasn't quite up for throwing money out to the dealer yet, so i reset my mass airflow sensor and since then the light has not returned. So it appears i have solved the problem or atleast for the time being
Old Apr 8, 2003
Dr5D's Avatar
if those lights come on most autoparts stores have a comp thingie that can at least say what its on for, just make sure they dont erase it!!! oh and
Old Apr 8, 2003
EEN's Avatar
EEN
EEN is an unknown quantity at this point
Yeah, listen to this man.....he knows what he is talking about!
Old Apr 10, 2003
sKwiD's Avatar
I Queef > You
sKwiD is on a distinguished road
My Maint Required light blinks about 5 times after I start the car. a few weeks ago was the first time I changed my own oil, so I guess that may be the case. I guess I should just push that button, unless you guys say otherwise...
Old Apr 10, 2003
ZSKCivic01's Avatar
Extreme Member
ZSKCivic01 is an unknown quantity at this point
This is what I did when mine came on. I went to autozone, if you don't have one in your area, find some place that has one of those things that logs onto your onboard computer, and they will give you the code to the problem. Afterwards, just call you honda service and ask them what that code means. Mine was due to a loose gas cap. The thing though is even after several days, the light didn't go off. To fix the problem, all I did was unplugged my battery for several minutes, I don't know if the time its unplugged matters, and when I connected everything back up, the light was off. If the light comes on again, then it is probably a seal or something, but chances are it was caused by the gas cap.
Old Apr 10, 2003
tdiddy's Avatar
tdiddy is an unknown quantity at this point
autozone is where i go, theres hundreds of reasons for that light to come on,some are pretty stupid, but i would have them check it to be safe before you reset it. Anyways it doesn't cost anything besides five minutes of your time.
Old May 1, 2003
mikek753's Avatar
mikek753 is an unknown quantity at this point
I have had this light on for a week.
When I had unplugged and plugged battery for a min then light went off.
But after two days it came back to on state
today I "resetted" it again and I don't know for how long.
my car has just 44k ml, but I already run out of warranty
in my area San Jose, CA no one store reads the code - I came to autozone too.
anything I can do by myself until go to Honda and pay $50+ for diagnostics check?
tnx
Old May 1, 2003
HappyGilmore's Avatar
HappyGilmore is an unknown quantity at this point
tnx
The ENGINE LIGHT comes on for a reason. If it keeps coming on after you have done everything that the manual asked you to check, then there is a major problem in the engine. Don't try to reset it yourself and later find out that your engine has caused another domino effect problem. Have the dealer run the codes for dianostics. Better to be safe than to be sorry.
If you still have warranty left, than run several ECU reports from different dealers if you want a peace of mind. This is my $0.02 to you.
Old May 3, 2003
PicCoLoboi02's Avatar
PicCoLoboi02 is on a distinguished road
mine is on but it's because i have a downpipe hehe (02 simulator is getting work on). Check your o2 sensors to see if it's loose or anything. Try replugging it and reset the ECU...do the bottom one of the cat.
Old May 6, 2003
bluericeburna2k2's Avatar
bluericeburna2k2 will become famous soon enoughbluericeburna2k2 will become famous soon enough
when i put my AEM SRI on my light came on and does not turn off its pissin me off for the longest time now
Old May 8, 2003
did you try resetting the ECU. CEL coming on from installing an intake...that's weird. I have CAI and no problems
Old May 8, 2003
Xuhme
21
Aug 7, 2023 03:40 PM
hernandexz
Oct 28, 2021 10:52 PM
jetcare101
May 8, 2015 01:33 PM
tylerginevan
Apr 27, 2015 12:29 PM
bahena08
Apr 11, 2015 05:09 PM
