check engine light
Old Mar 14, 2003
1983's Avatar
1983 is an unknown quantity at this point
check engine light
i just got an injen cold air intake and was wondering if the check engine light will flash after installing the cai on????
thanx[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Mar 17, 2003
Weaponx12o's Avatar
umm.. un hook the battery and put it back on again.. or remove then put the sensor back on the intake.. i forget how i did it when i installed my aem sri.. but i did something similar to what i said
Old Mar 17, 2003
01WingsWestCivic's Avatar
7thgen Man-gina
01WingsWestCivic is an unknown quantity at this point
I had no such prolem when I installed my Injen intake. The only thing to be cautious of is when you disconnect the battery, if you have your stock CD player, youll have to reset the code in it. I believe its a 5 digit code that should be on a small card and on the back of the head unit. If you dont have the card youll have to remove the factory HU to get the code which is a pain in the **** since you have to remove the dash. Hope that helps.
Old Mar 17, 2003
marklab's Avatar
marklab is an unknown quantity at this point
Isn't the 5 digit code used for security to deter the HU from being stolen? If they print the code on the back of the HU dosen't that pretty much defeat the purpose of the code?
Xuhme
21
Aug 7, 2023 03:40 PM
hernandexz
Oct 28, 2021 10:52 PM
jetcare101
May 8, 2015 01:33 PM
tylerginevan
Apr 27, 2015 12:29 PM
bahena08
Apr 11, 2015 05:09 PM
