gauge needle problem
Old Feb 10, 2003
02NCcivic's Avatar
02NCcivic is an unknown quantity at this point
i'm new to this forum and i'm wondering if someone can help. i just installed indiglo gauges on my 02 civic and i'm having a problem with the gas needle. it doesn't seem to have a stop anymore. i pulled the gauges and set the needle at the normal point when the car is off and started it and it seemed to be fine until i cut it off and it dropped past the stop i set it at. the next time it went didn't go as far up when i started it and went further down. what can i do to fix it or is it shot to **** now? thanks for your help
Old Feb 11, 2003
sg2kca's Avatar
sg2kca is an unknown quantity at this point
seems to me as its busted. just take the indilgo gauges off, put the cluster back, go to your dealer and play dumb.
Old Feb 11, 2003
02NCcivic's Avatar
but all i would really need is to create a stop point like what is used for the tach and speedometer right? i can do this without it even being noticeable i believe and without much effort other than pulling the plastic trim and cover.
Old Feb 11, 2003
Krepoort's Avatar
Krepoort is an unknown quantity at this point
Quote
[hr]Originally posted by: 02NCcivic
but all i would really need is to create a stop point like what is used for the tach and speedometer right? i can do this without it even being noticeable i believe and without much effort other than pulling the plastic trim and cover.[hr]
You can definitely try that, but the thing is, the internals might be messed up. You might wanna take off the clear plastic, have the gauge cluster hooked up and use your finger as a stopping point. Try starting and killing the engine a few times to see if it would work. If it does, then glue a needle or something as a stop point, else do what sg2kca said. Good luck.
-Kre
Old Feb 11, 2003
02NCcivic's Avatar
that's exactly what i was going to do. i played with it some the yesterday and it held the first time i set it but without the stop it continued to fall each time. i think this will work but i'll just fill the tank so i have a reference point and try it later this week. thanks.
Old Feb 12, 2003
MrMondayNite's Avatar
MrMondayNite is an unknown quantity at this point
Hey how about filling your gas tank up and then rotate your gas guage so the needle will move up to F or Full. I never noticed that there was a stop on the gas gauge and the temp guage,but I did notice it on the speedometer and Tachometer. Guess I'll check that next time I go to the car. Hope this Helps.
Old Mar 30, 2003
NaHoOnEyYa's Avatar
NaHoOnEyYa is an unknown quantity at this point
Wink
my car had the same problem when i had reverse indiglos on! when i took it to the dealer, they blamed it on the indiglo, and said it won't go under warranty...but a month later, with the indeglo off, they said they would be glad to fix and replace it for me...so i got my self a brand new guages and a big fat ZERO on my oddometer! hope it helps...
Old Mar 31, 2003
bhaz413's Avatar
Support your local 81
From: In the land of milk and butter, Massachusetts, US
bhaz413 is an unknown quantity at this point
zero? i doubt that. the guage cluster doesnt keep track of your milage. Your computer does.
Old Mar 31, 2003
NaHoOnEyYa's Avatar
Talking
Oh but it did....i have total of 144 miles right now....before i had 24000~^^;; they had to put a little sticker by the door saying that the mile was reseted at 24000...
tylerginevan
Apr 27, 2015 12:29 PM
LX2slow
Dec 20, 2001 08:33 AM
manicEL
Dec 10, 2001 06:33 PM
ShadyMilkMan
Nov 20, 2001 06:05 PM
meels808
Nov 15, 2001 07:16 AM
