Engine Shakes and Check Engine comes on
Old Feb 2, 2003
dhuong23's Avatar
dhuong23 is an unknown quantity at this point
Okay, so i was driving to the bank and after i was done i started my car and the engine started to shake really bad and the whole car shook and then the ChECK Engine light came on.. It only shook when i stopped on a redlight or put it to park but when i drove it, it didn't shake. So i finally drove it like 15 miles to my friend's house and then stopped it, i let it cool down alittle and then started it and the shaking stopped but the check engine still came on. So my brother took it to a cheap mechinic and he said it was the Oxygen Sensor byt just lookin at it. So he disconnected the battery and the reset the computer.. Now i'm freaked, he said don't worry about it and its fine. The Car has 45000 miles, and is due for its next oil change. If i take it to honda they will charge me a grip of money to get it fixed, What should i DO???
Old Feb 2, 2003
flotsamm's Avatar
See if you can find a reputable shop that has a code scanner and can scan your car for any MIL or diagnostic errors. A good shop should be able to tell you what the codes mean and give you some possible solutions. If the solutions are way beyond your mechanical capability, take it to the dealer or shop.
Though its probably not the problem, but did you check out your motor mounts? I see a few posts here and there about peeps replacing these, mostly do to racing though.
Old Feb 2, 2003
turboslug's Avatar
Super Hoser
turboslug will become famous soon enoughturboslug will become famous soon enough
don't you guys have warantee on the car? can't u just brink it back to a dealer for a free fix?
Xuhme
21
Aug 7, 2023 03:40 PM
hernandexz
Oct 28, 2021 10:52 PM
mistermenphis22
Apr 3, 2016 08:06 AM
smmahan
Apr 15, 2015 08:17 PM
bahena08
Apr 11, 2015 05:09 PM
