Brake noise I guess?
Old Jan 4, 2003
SoNiCcIvIc's Avatar
SoNiCcIvIc is an unknown quantity at this point
Hey, I have about 27.5 thousand miles on my car now and as I was driving (around 85mph on a freeway) I hear a loud squealing sound coming from the front of my car. It sounds similar to when brakes squeal as some cars do when they brake to a stop but I wasn't braking at all. I explained it to a friend... and that person's friend... said to replace the brake shoes. Brake "shoes"? I know some of the parts to the brakes like the disc and the caliper but the "shoe" is new. Anyway do you think that person's right? And can someone explain what the brake shoe is? Thanks. [IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Old Jan 4, 2003
SoNiCcIvIc's Avatar
Bump. [IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Old Jan 5, 2003
SoNiCcIvIc's Avatar
Entering day 2.[IMG]i/expressions/face-icon-small-cool.gif[/IMG]
Old Jan 5, 2003
ACEM2's Avatar
NytRyder2k2's Son
ACEM2 is an unknown quantity at this point
sounds like u need new brake pads
Old Jan 5, 2003
flotsamm's Avatar
Not sure why he would say you need new shoes from your description, but you might. Usually when you cruising and dont touch the brakes it wont squeal. It should only squeal when the brakes are applied, unless theres something else wrong.
About shoes, your rear brakes are a drum/shoe setup. You have two shoes per side inside each drum. In the front, you have a rotor/caliper setup where the caliper holds two brake pads on each side of the rotor.
If you got 27K out of your brakes already, it wouldnt hurt to inspect each wheel.
Old Jan 6, 2003
SoNiCcIvIc's Avatar
It's really strange. I've been driving my car lately and I haven't heard the sound since. But I am gonna inspect to brakes myself and check my pads on the front. It definitely wasn't coming from the rear, so the "shoes" are fine.
Old Jan 8, 2003
Pinoy3LeR's Avatar
Pinoy3LeR is an unknown quantity at this point
it might be the break limiter,it tends to sound off when your brake pads need replacing[IMG]i/expressions/face-icon-small-cool.gif[/IMG]
or ypu could check your pads sometimes dirt could also cause the sound
Old Jan 8, 2003
flotsamm's Avatar
Quote
[hr]Originally posted by: Pinoy3LeR
or ypu could check your pads sometimes dirt could also cause the sound[hr]
I think he means the brake squeek indicator..
Old Jan 9, 2003
Pinoy3LeR's Avatar
yeah its the brake squeek indicator[IMG]i/expressions/face-icon-small-tongue.gif[/IMG] thank's
GolNat
Suspension DIY
May 12, 2022 06:49 AM
sbi
20
Oct 23, 2015 01:34 PM
TiggerDX
Jun 18, 2015 01:43 PM
CapYoda
Jan 7, 2002 03:20 PM
Sparty
Nov 15, 2001 04:55 PM
